alhlhli Posted February 15 Share Posted February 15 Hi All Engineer Here is the door or window symbol and its number below it I need to merge the two texts into one text I was using the txt2mtxt function But you only need to select every two that are close together If all are selected, there will be a problem Is there a Lisp for this process? So that it recognizes writings that are close to each other and combines them https://www12.0zz0.com/2024/02/15/09/496206091.png Quote Link to comment Share on other sites More sharing options...
alhlhli Posted February 15 Author Share Posted February 15 By artificial intelligence I extracted this lisp but it didn't work It may need a little modification (defun c:MergeCloseTexts ( ) (setq entlist (ssget)) (while (entnext entlist) (setq ent (entnext entlist)) (if (and (eq (enttype ent) "TEXT") (not (zerop (distance (getpoint ent) (getpoint (entnext ent)))))) (command "_.txt2mtxt" ent (entnext ent)) ) ) ) FF_DOOR_WINDOWS.dwg Quote Link to comment Share on other sites More sharing options...
fuccaro Posted February 15 Share Posted February 15 I am not as smart as AI, so my program is longer: (defun c:pp() (setq ss (ssget "I" (list '(0 . "TEXT"))) d (getdist "max distance? ")) (while (> (sslength ss) 0) (setq t1 (ssname ss 0) poz1 (cdr (assoc 10 (entget t1)))) (ssdel t1 ss) (setq i -1 gotIt nil) (while (not gotIt) (setq t2 (ssname ss (setq i (1+ i))) poz2 (cdr (assoc 10 (entget t2))) gotIt (< (distance poz1 poz2) d)) ) (ssdel t2 ss) (bind t1 t2) ) ) (defun bind (a b) (setq ya (caddr (assoc 10 (entget a))) yb (caddr (assoc 10 (entget b))) lst (if (> ya yb) (list a b) (list b a)) el (entget (car lst)) tx (cdr (assoc 1 el)) tx (strcat tx " / " (cdr (assoc 1 (entget (cadr lst))))) el (subst (cons 1 tx) (assoc 1 el) el) ) (entmod el) (entdel (cadr lst)) ) When it asks for "max distance" enter how close is a text to its pair. You may answer with two clicks to define the distance, or by entering it from the keyboard. For a given text, the program will search its pair within that distance. Edit: I just seen that you try to make an Mtext... This program will make a Text. Sorry, no more time to change the Lisp... Quote Link to comment Share on other sites More sharing options...
Steven P Posted February 15 Share Posted February 15 1 hour ago, fuccaro said: I am not as smart as AI, so my program is longer: ... but your programme works? Quote Link to comment Share on other sites More sharing options...
fuccaro Posted February 15 Share Posted February 15 I hope so... 1 Quote Link to comment Share on other sites More sharing options...
fuccaro Posted February 15 Share Posted February 15 @alhlhli In the program I posted for you, you could change the call for the bind function (bind t1 t2) with a call for the text2mtxt and you will get the result as mtext Quote Link to comment Share on other sites More sharing options...
