Arizona Posted February 14, 2024 Posted February 14, 2024 (edited) Shift for temp Orthomode quit working yesterday. It flattens out the ortho, but does not let me pick (the endpoint of a line for example, or the rotation of a block). I can left click the mouse all I want but nothing happens. Any quess why? Thanks. EDIT: I just found that Shift to Deselect is also not working. Edited February 14, 2024 by Arizona Quote
CyberAngel Posted February 14, 2024 Posted February 14, 2024 Acording to Autodesk, you may need to use the Function key and F8 at the same time. Or you may need to redefine your ortho key (see this page). Quote
Arizona Posted February 14, 2024 Author Posted February 14, 2024 7 minutes ago, CyberAngel said: Acording to Autodesk, you may need to use the Function key and F8 at the same time. Or you may need to redefine your ortho key (see this page). Yes, I saw that too, but I do not have a Fn (function) key, so it did not help. Redefining the ortho key seems odd, because it always worked previously, then suddenly stopped. Seems more like a Setvar issue. Quote
