Aditya Bagaskara Posted February 13 Posted February 13 Is there a way to access any data from Drawing Units? I suppose I can use the vla syntax, but I don't know which one... Thank you for the help! Quote
fuccaro Posted February 13 Posted February 13 AutoLisp can access the system variables. With GETVAR you can read the values stored in INSUNITS or MEASUREINIT. Some variables also can be changed using the SETVAR command. Just find the sysvar that is relevant for your task. 1 Quote
Aditya Bagaskara Posted February 14 Author Posted February 14 9 hours ago, fuccaro said: AutoLisp can access the system variables. With GETVAR you can read the values stored in INSUNITS or MEASUREINIT. Some variables also can be changed using the SETVAR command. Just find the sysvar that is relevant for your task. Thank you! Do you know where I can access a list or a website containing all of them? Quote
BIGAL Posted February 14 Posted February 14 (edited) Setvar ? * is your answer as 1st step. Press Enter Enter ........ Setvar ? T* Edited February 14 by BIGAL 1 Quote
Isaac26a Posted February 14 Posted February 14 Sysvdlg shows you all the variables and explain what's it's use 1 Quote
Aditya Bagaskara Posted February 14 Author Posted February 14 Thank you all for the answers, the next question is, all the value is stored in integer. How do I know if it's cm or mm or something? Do I have to list them all myself? Quote
pkenewell Posted February 14 Posted February 14 (edited) @Aditya Bagaskara Study these System Variables. You can look them up in AutoCAD's help bar: LUNITS = Integer representing the liner units type; i.e. Scientific, Decimal, Fractional, etc.. LUPREC = Integer representing the unit precision; i.e. how many places behind the decimal point. MEASUREMENT = 0 is Imperial (inches), and 1 is Metric (mm, cm, m) MEASUREINIT = integer representing whether imperial (0) or metric (1) Hatch patterns and Linetypes are used. There are more, but those the the main ones. Technically - AutoCAD is "scaleless", meaning you define the scale of 1 unit, whether that is 1 mm or 1 meter. The system variables above control how that scaling is displayed and calculated. In Imperial measurement however, Fractional and Architectural scale are dependant on inches being the 1 unit, because of the way they are displayed. Edited February 14 by pkenewell 1 Quote
Aditya Bagaskara Posted February 14 Author Posted February 14 18 minutes ago, pkenewell said: @Aditya Bagaskara Study these System Variables. You can look them up in AutoCAD's help bar: LUNITS = Integer representing the liner units type; i.e. Scientific, Decimal, Fractional, etc.. LUPREC = Integer representing the unit precision; i.e. how many places behind the decimal point. MEASUREMENT = 0 is Imperial (inches), and 1 is Metric (mm, cm, m) MEASUREINIT = integer representing whether imperial (0) or metric (1) Hatch patterns and Linetypes are used. There are more, but those the the main ones. Technically - AutoCAD is "scaleless", meaning you define the scale of 1 unit, whether that is 1 mm or 1 meter. The system variables above control how that scaling is displayed and calculated. In Imperial measurement however, Fractional and Architectural scale are dependant on inches being the 1 unit, because of the way they are displayed. Thanks for the details! 1 Quote
