pyou Posted February 12, 2024 Posted February 12, 2024 Hi Is there a way to modify this lisp to make it also work on 3D Polylines? (DEFUN C:ARRAY-VERTICES (/ *error* add_vtx in interval pl pt LSE CNT) (defun *error* (s) (or (wcmatch (strcase s) "*BREAK,*CANCEL*,*EXIT*") (prompt (strcat "\nError: " s))) (setq LSE nil) (princ) ) ;;*error* (defun add_vtx (add_pt ent_name / obj pct) (setq obj (vlax-ename->vla-object ent_name) pct (trans (vlax-curve-getpointatparam obj add_pt) 0 ent_name) ) (vla-addvertex obj (1+ (fix add_pt)) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (quote (0 . 1))) (list (car pct) (cadr pct)) ) ) ) ) ;;add_vtx ;;Main (initget 15) (setq LSE (ssget (list (quote (0 . "LWPOLYLINE")))) interval (getdist "\nSpecify interval: ") in interval CNT 0 ) (while (< CNT (sslength LSE)) (setq pl (ssname LSE CNT)) (while (setq pt (vlax-curve-getpointatdist pl interval)) (command "_.POINT" pt) ;;Test! (add_vtx (vlax-curve-getparamatpoint pl (vlax-curve-getclosestpointto pl pt)) pl) (setq interval (+ interval in)) ) (setq interval in CNT (1+ CNT) ) ) (setq LSE nil) (princ) ) ;;C:ARRAY-VERTICES (vl-load-com) Thank you Quote
Steven P Posted February 13, 2024 Posted February 13, 2024 The basic method used in this routine only works on 2d polylines, to make this more versatile and work on 3d polylines and 2d polyline would need this part re-written. Not a quick fix though Quote
pyou Posted February 13, 2024 Author Posted February 13, 2024 it would be great if it could work on 3d Polylines only. Quote
Tsuky Posted February 15, 2024 Posted February 15, 2024 Hi, Try this for 3dPolyline (defun l-coor2l-pt (obj lst flag / ) (if lst (cons (list (car lst) (cadr lst) (if flag (+ (if (vlax-property-available-p obj 'Elevation) (vlax-get obj 'Elevation) 0.0) (caddr lst)) (if (vlax-property-available-p obj 'Elevation) (vlax-get obj 'Elevation) 0.0) ) ) (l-coor2l-pt obj (if flag (cdddr lst) (cddr lst)) flag) ) ) ) (defun c:add_vertex-3D ( / ss AcDoc Space interval in n obj_vla l_coor last_p pt pt_vtx new_vtx prm indx flag nw_coor) (princ "\nSelecting an unfited 3Dpolyline") (cond ((setq ss (ssget '((0 . "POLYLINE") (-4 . "<AND") (-4 . "&") (70 . 8) (-4 . "<NOT") (-4 . "&") (70 . 4) (-4 . "NOT>") (-4 . "AND>")))) (initget 15) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (eq (getvar "CVPORT") 1) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) interval (getdist "\nSpecify interval: ") in interval ) (repeat (setq n (sslength ss)) (setq obj_vla (vlax-ename->vla-object (ssname ss (setq n (1- n)))) l_coor (l-coor2l-pt obj_vla (vlax-get obj_vla 'Coordinates) T) last_p (last l_coor) ) (while (setq pt (vlax-curve-getPointAtDist obj_vla interval)) (setq pt_vtx (vlax-curve-getClosestPointToProjection obj_vla (trans pt 1 0) '(0 0 1) nil) new_vtx (vlax-3d-point last_p) prm (vlax-curve-getParamAtPoint obj_vla pt_vtx) indx -1 ) (vla-AppendVertex obj_vla new_vtx) (repeat (if (vlax-curve-isClosed obj_vla) (fix (vlax-curve-getEndParam obj_vla)) (1+ (fix (vlax-curve-getEndParam obj_vla)))) (setq indx (1+ indx)) (if (or (not (eq indx (1+ (fix prm)))) flag) (setq nw_coor (cons (vlax-curve-getPointAtParam obj_vla indx) nw_coor)) (setq nw_coor (cons pt_vtx nw_coor) indx (1- indx) flag T) ) ) (setq indx -1) (foreach e (reverse nw_coor) (vlax-put-property obj_vla 'Coordinate (setq indx (1+ indx)) (vlax-3d-point e)) ) (setq l_coor (l-coor2l-pt obj_vla (vlax-get obj_vla 'Coordinates) T) last_p (last l_coor) nw_coor nil flag nil interval (+ interval in) ) ) (setq interval in) ) ) (T (princ "\nNothing selected")) ) (prin1) ) 1 Quote
pyou Posted February 15, 2024 Author Posted February 15, 2024 17 hours ago, Tsuky said: Hi, Try this for 3dPolyline (defun l-coor2l-pt (obj lst flag / ) (if lst (cons (list (car lst) (cadr lst) (if flag (+ (if (vlax-property-available-p obj 'Elevation) (vlax-get obj 'Elevation) 0.0) (caddr lst)) (if (vlax-property-available-p obj 'Elevation) (vlax-get obj 'Elevation) 0.0) ) ) (l-coor2l-pt obj (if flag (cdddr lst) (cddr lst)) flag) ) ) ) (defun c:add_vertex-3D ( / ss AcDoc Space interval in n obj_vla l_coor last_p pt pt_vtx new_vtx prm indx flag nw_coor) (princ "\nSelecting an unfited 3Dpolyline") (cond ((setq ss (ssget '((0 . "POLYLINE") (-4 . "<AND") (-4 . "&") (70 . 8) (-4 . "<NOT") (-4 . "&") (70 . 4) (-4 . "NOT>") (-4 . "AND>")))) (initget 15) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (eq (getvar "CVPORT") 1) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) interval (getdist "\nSpecify interval: ") in interval ) (repeat (setq n (sslength ss)) (setq obj_vla (vlax-ename->vla-object (ssname ss (setq n (1- n)))) l_coor (l-coor2l-pt obj_vla (vlax-get obj_vla 'Coordinates) T) last_p (last l_coor) ) (while (setq pt (vlax-curve-getPointAtDist obj_vla interval)) (setq pt_vtx (vlax-curve-getClosestPointToProjection obj_vla (trans pt 1 0) '(0 0 1) nil) new_vtx (vlax-3d-point last_p) prm (vlax-curve-getParamAtPoint obj_vla pt_vtx) indx -1 ) (vla-AppendVertex obj_vla new_vtx) (repeat (if (vlax-curve-isClosed obj_vla) (fix (vlax-curve-getEndParam obj_vla)) (1+ (fix (vlax-curve-getEndParam obj_vla)))) (setq indx (1+ indx)) (if (or (not (eq indx (1+ (fix prm)))) flag) (setq nw_coor (cons (vlax-curve-getPointAtParam obj_vla indx) nw_coor)) (setq nw_coor (cons pt_vtx nw_coor) indx (1- indx) flag T) ) ) (setq indx -1) (foreach e (reverse nw_coor) (vlax-put-property obj_vla 'Coordinate (setq indx (1+ indx)) (vlax-3d-point e)) ) (setq l_coor (l-coor2l-pt obj_vla (vlax-get obj_vla 'Coordinates) T) last_p (last l_coor) nw_coor nil flag nil interval (+ interval in) ) ) (setq interval in) ) ) (T (princ "\nNothing selected")) ) (prin1) ) Thank you Tsuky, its perfect! Quote
pyou Posted May 4, 2024 Author Posted May 4, 2024 (edited) Would it be possible to modify this lisp to specify interval and gaps if required? For example desired intervals are at 1m and gaps are 0.5m. Gaps to be removed if required and only 3d polyline segments left. Thank you Example drawing attached test.dwg Edited May 4, 2024 by pyou Quote
Tsuky Posted May 5, 2024 Posted May 5, 2024 I did this, but tested superficially. I hope it does what you want! Cut_Poly3D.lsp 1 Quote
pyou Posted May 22, 2024 Author Posted May 22, 2024 On 05/05/2024 at 23:52, Tsuky said: I did this, but tested superficially. I hope it does what you want! Cut_Poly3D.lsp 4.82 kB · 4 downloads Tsuky, I have noticed if I split polyline into equal segment lengths for example 0.50m and 0.50m its not working, but if do 0.50m and 0.51m it works, do you know what causing this and what modification would need? Quote
Tsuky Posted May 23, 2024 Posted May 23, 2024 You're right, it's buggy in this specific case. Your tip is good If I want to apply your tip to the code I would add after line 46 (if (equal in in2 1E-08) (setq in2 (+ in2 1E-07))) because I am doing a test from line 114 to 126 to 1E-08 on the inter-distance and if in = in2; it erases everything. Which explains why only the last segment remains. This modification may be enough because modifying my code would become more complicated. This would be another algorithm and it's worth my time... Is this only for a representation? 1E-07 is really little and is sufficient for a representation of discontinuity. 1 Quote
pyou Posted May 23, 2024 Author Posted May 23, 2024 4 hours ago, Tsuky said: You're right, it's buggy in this specific case. Your tip is good If I want to apply your tip to the code I would add after line 46 (if (equal in in2 1E-08) (setq in2 (+ in2 1E-07))) because I am doing a test from line 114 to 126 to 1E-08 on the inter-distance and if in = in2; it erases everything. Which explains why only the last segment remains. This modification may be enough because modifying my code would become more complicated. This would be another algorithm and it's worth my time... Is this only for a representation? 1E-07 is really little and is sufficient for a representation of discontinuity. yes, your modification definitely fixed bug and works now. Thank you! Quote
pyou Posted June 12, 2024 Author Posted June 12, 2024 (edited) . Edited August 12, 2024 by pyou Quote
