Hi everyone, here a simple vba code to delete layers. It previously erases all the layer's content in order to make deletion possible. Hope it helps someone.
First of all, you need to create a UserForm with a ListBox control named "LBLayers", which must have the MultiSelect property set to "2-fmMultiSelectExtended". Also you´ll need a command button named "CBEraseLayer", and a quit control if you want.
Add the following code to the UserForm code
Option Explicit
Public Sub LoadLayersList(LList As ListBox)
   Dim tlay As AcadLayer
   LList.Clear
   For Each tlay In ThisDrawing.Layers
       Call LList.AddItem(tlay.Name)
   Next tlay
   LList.ListIndex = 0
End Sub
Private Sub CBEraseLayer_Click()
   Dim sset As AcadSelectionSet
   Dim FilterType(0) As Integer
   Dim FilterData(0) As Variant
   Dim nlays As Integer, i As Integer
   nlays = LBLayers.ListCount
   If ThisDrawing.SelectionSets.Count >= 1 Then
       For i = ThisDrawing.SelectionSets.Count - 1 To 0 Step -1
           ThisDrawing.SelectionSets.Item(i).Delete
       Next i
   End If
   FilterType(0) = 8
   For i = 0 To nlays - 1
       If LBLayers.Selected(i) Then
           FilterData(0) = LBLayers.List(i)
           Set sset = ThisDrawing.SelectionSets.Add("SSAUX01")
           Call sset.Select(acSelectionSetAll, , , FilterType, FilterData)
           Call sset.Erase
           Call sset.Delete
           ThisDrawing.Layers.Item(LBLayers.List(i)).Delete
       End If
   Next i
   Call LoadLayersList(LBLayers)
   Exit Sub
End Sub
Private Sub CBQuit_Click()
   UFEraseLayer.Hide
End Sub
Private Sub UserForm_Activate()
End Sub
Also, you will need a module with a sub in order to launch the macro from autocad, the launcher could be something like this
Public Sub EraseLayers()
   Load UFEraseLayer
   UFEraseLayer.Show
   Unload UFEraseLayer
End Sub
Now, you can call the Form from the macros menu, and erase all the selected layers together with it´s contents.
NOTE: Use it carefully! :nuke:
  • Replies 24
  • Lee Mac
    12
  • TheRedGuy
    6
  • Hunter
    5
  • CADgirl
    1
Does it account for the layer thats being deleted being layer "0" or the current layer?
The UserForm loads all the layers names on the ListBox and let´s the user to select which layers are going to be deleted.
Regarding your question, no, it doesn´t check that layer "0" cannot be deleted, so adding an if inside the layers list to avoid this situation that clearly would lead to a runtime error, would improve the code. Also, check if the layer is locked or not and ask if you want to delete it anyway. In that case, unlock the layer and proceed, otherwise don´t try to delete the objects inside the layer, this also would lead to a runtime error.
Regards
Alejandro
My apologies, the text I've places few minutes ago is almost unreadable, (I'm out of fit with my english). I hope you can understand what I've tried to say, if you want I can rethink the message, it would be a nice exercise.
Regards
Alejandro
The previous message is a mess, I'm sorry. If you're unable to understand what I'm trying to say, I´ll be happy to rewrite it.
Regards
Alejandro
I'm sure this is a stupid question, but what is the difference between this and laydel? (I obvioulsy don't know anything about codes and all that) :oops:
I didn't know about that command! well, at least it was a programming excercise! :)
Regards
For a programming exercise in LISP, note that a layer can be deleted with a simple one-liner:
(vl-catch-all-apply 'vla-Delete (list (vlax-ename->vla-object (tblobjname "LAYER" "layername"))))
But there are many ways to accomplish the same thing. :P
Or, with error trappings for layer 0 and current layer... kindly provided by ASMI:
(defun DeleteLayer(Name / layCol dLay oVal)
 (vl-load-com)
 (if
   (and
     (/= Name "0") ; Check its not Layer 0
     (/= (strcase Name)(getvar "CLAYER")) ; Check its not Current Layer
     ); end or
     (setq layCol(vla-get-Layers
           (vla-get-ActiveDocument
             (vlax-get-acad-object)))) ; Retrieve Current Layer Collection
      (if(vl-catch-all-error-p
          (setq dLay(vl-catch-all-apply 'vla-Item
        (list layCol(strcat Name))))) ; Retrieve Layer Object Name from Layer Collection?
        (princ "\nLayer does not exist! ")
            (list dLay))) ; If Possible, Delete the Layer
        (princ "\nCan't delete layer in use! ")
      (setq oVal T)
    ); end if
       ); end if
     ); end progn
   (princ "\nCan't delete active layer or layer \"0\"! ")
  ); end if
 oVal
); end of DeleteLayer
Thanks, Lisp is a pending issue. Despite that I'm able to do some programming using other list oriented languages/programs, such as Mathematica, I´ve never been able to do something using Lisp. Probably the best time investement would be in ObjectARX or something related to .NET, what do you think about?
Hi,Lee~
Is this a subroutine ?
Would u please tell me how to run it directly?
Thanks ~
 (vl-load-com)
 (if
   (and
     ); end or
      (setq oVal T)
    ); end if
       ); end if
     ); end progn
  ); end if
 oVal
Hi Hunter,
Yes, it is a sub-function, and requires one argument - namely the layer name.
Something like this:
(defun DeleteLayer  (Name / layCol dLay oVal)
 (vl-load-com)
 (if (and (/= Name "0")
      (/= (strcase Name) (getvar "CLAYER")))
      (setq layCol (vla-get-Layers
      (if (vl-catch-all-error-p
        (setq dLay    (vl-catch-all-apply 'vla-Item
             (list layCol (strcat Name)))))
          (vl-catch-all-apply 'vla-Delete (list dLay)))
      (setq oVal T))))
    (princ "\nCan't delete active layer or layer \"0\"! "))
 oVal)
(defun c:test (/ lay)
 (setq lay (getstring "\nType Name of Layer..."))
 (DeleteLayer lay)
 (princ))
I suppose you could also include coding to delete everything on that layer before deleting the layer...
 (vl-load-com)
      (setq oVal T))))
 oVal)
(defun c:test (/ lay ss)
 (setq ss (mapcar 'cadr (ssnamex (ssget "X" (list (cons 8 lay))))))
 (mapcar 'entdel ss)
 (DeleteLayer lay)
 (princ))
Excuse my last post, doesn't allow for an empty selection set... may return error lseltp nil.
You could compress the code into this:
(defun DeleteLayer  (Name / ss)
 (vl-load-com)
 (if (and (/= Name "0") (tblsearch "LAYER" Name)
   (if    (setq ss (ssget "X" (list (cons 8 lay))))
     (mapcar 'entdel (mapcar 'cadr (ssnamex ss))))
       (list (vlax-ename->vla-object (tblobjname "LAYER" Name)))))
     (princ "\nError Deleting Layer")))
   (princ "\nLayer not found or Current Layer or Layer \"0\"")))
 (setq lay (getstring "\nSpecify Layer to Delete..."))
 (DeleteLayer lay)
 (princ))
Hi, Lee:
Thanks for your kindly reply~
It's really appreciated!
Yeah, it works fine~
And it would be perfect if there would be a dialogue box to selecte the layers:)
No Problems Hunter, did my last code function properly? :)
Haha, you love your Dialog Boxes :)
I could create one for it, but, tbh, isn't this the same as just going into the layer manager and deleting the layer from there?
