Ceiling Grid lisp not working right
I need a lisp routine to do ceiling grids that works. The Cgrid.lsp works great, But when you specfie a centen locate it does not start where I specify. Can anyone look at this lisp file and fix it for me.
Thanks
Lisp File:
(defun c:cgrid ()
(setvar "cmdecho" 0)
(setq DCL_ID (load_dialog "CGRID.DCL"))
(if (not (new_dialog "cgrid" DCL_ID)) (exit))
(action_tile "grid_1" "(setq GRID \"clg_2x2\")")
(action_tile "grid_2" "(setq GRID \"clg_2x4\")")
(action_tile "ang_1" "(setq ANG \"0\")")
(action_tile "ang_2" "(setq ANG \"45\")")
(action_tile "ang_3" "(setq ANG \"90\")")
(action_tile "ang_4" "(setq ANG \"135\")")
(action_tile "object" "(setq SEL 1)(done_dialog 4)")
(action_tile "point" "(setq SEL 2)(done_dialog 4)")
(action_tile "edit" "(setq SEL 3)(done_dialog 4)")
(setq DO_NEXT (start_dialog))
(unload_dialog DCL_ID)
(if (= DO_NEXT 4) (progn
(if (= SEL 1)
(setq OBJ (ssget))
(setq PT (getpoint "\nSelect starting point of grid:"))
(setq XCORD (car PT))
(setq YCORD (cadr PT))
(setq SP (list XCORD YCORD))
(setvar "snapbase" SP)
(command ".bhatch" "p" GRID "1.0" ANG "s" OBJ "" "")
(command "snapbase" "0,0")
(if (= SEL 2)
(setq PNT (getpoint "\nPick internal point:"))
(command ".bhatch" "p" GRID "1.0" ANG PNT "")
(defun rtd (A)
(/(* A 180.0) PI)
(if (= SEL 3)
(setq EROB (entsel "\nSelect ceiling grid to edit:"))
(setq GRID (entget (car EROB)))
(setq RAD (assoc 52 GRID))
(setq RAD (cdr RAD))
(setq GRID (assoc 2 GRID))
(setq GRID (cdr GRID))
(setq PT (getpoint "\nPick new starting point:"))
(setq OBJ (ssget))
(setq ANG (rtd RAD))
(command ".erase" EROB "")
;;END CGRID.LSP
DLC File:
cgrid : dialog {
label = "Reflected Ceiling";
spacer_1;
: row {
: boxed_radio_column {
label = "Ceiling Grid Size...";
: radio_button {
label = "24in. x 24in. (Suspended Ceiling OR Access Floor)";
key = "grid_1";}
: radio_button {
label = "24in. x 48in. (Suspended Ceiling)";
key = "grid_2";}
spacer_1;
: row {
: boxed_radio_row {
label = "Grid Angle...";
width = 20;
: radio_button {
label = "0";
key = "ang_1";}
: radio_button {
label = "45";
key = "ang_2";}
: radio_button {
label = "90";
key = "ang_3";}
: radio_button {
label = "135";
key = "ang_4";}
spacer_1;
: boxed_radio_row {
label = "Boundary Options...";
: button {
label = "Select Polyline";
key = "object";
width = 16;
fixed_width = true;}
: button {
label = "Pick Internal Point";
key = "point";
width = 20;
: button {
key = "edit";
label = "Edit Start point";
width = 16;
ok_cancel;
CGRID.zip
Not sure if the attached is what you are looking for, But give it a try.
Good Luck,
The Buzzard
CFT.zip
I tried this program at work and every time I select my own starting within the side area of the room it wouldn't start where I place it, But when I just tryed it on my home PC and it works.
I'm going to have to look at my setting. :oops:
It is funny that every time I tryed it at work, it would not work on AutoCAD 2008. But in AutoCAD 2004 it works fine.:huh:
something is setup different in AutoCAD 2008.
Any one have any idea's?
Thanks
cadmando2,
Not sure what would prevent it from running. I tested it in 2004 & 2009 and it works fine in both. Make sure you have the latest service packs for 2008. Other then that, I have no idea what would cause the problem.
Let me know what you found when you get it working.
The Buzzard
