BLOACH85 Posted March 2, 2009 Author Posted March 2, 2009 Yea its been rough ive been up for atleast 36 hours and 4 chain-saw blades latter. But Thank God no one was hurt. But ok i tested it and it showed me the crossing entitys now what am i suppose to do with that?? Quote
Lee Mac Posted March 2, 2009 Posted March 2, 2009 Ahh, I have a better idea - how about using the points of intersection and the entity and using the break command... Quote
BLOACH85 Posted March 2, 2009 Author Posted March 2, 2009 hey that will work perfectly i didnt even think about that. Quote
BLOACH85 Posted March 2, 2009 Author Posted March 2, 2009 But how will i incorporate the points and select the rect without breaking it also? Quote
Lee Mac Posted March 2, 2009 Posted March 2, 2009 I have this so far... but will only break when things intersect twice... only tested on lines also... (defun ssinter (ss rec / vlst i j obj1 iarr iLst ptLst) (setq i (length ss)) (while (not (minusp (setq i (1- i)))) (setq obj1 (nth i ss) iarr (vlax-variant-value (vla-intersectwith obj1 rec acextendnone))) (if (> (vlax-safearray-get-u-bound iarr 1) 0) (progn (setq iLst (vlax-safearray->list iArr)) (while (not (zerop (length iLst))) (setq ptLst (cons (list (car iLst) (cadr iLst) (caddr iLst)) ptLst) iLst (cdddr iLst))) (setq ptLst (cons (vlax-vla-object->ename obj1) ptLst) mainLst (cons ptLst mainLst)))))) (defun c:test (/ rect mainLst) (vl-load-com) (setq rect (car (entsel "\nSelect Rectangle..."))) (ssinter (mapcar 'vlax-ename->vla-object (vl-remove-if '(lambda (x) (eq x rect)) (mapcar 'cadr (ssnamex (ssget "X" (list (cons 410 (getvar "CTAB")))))))) (vlax-ename->vla-object rect)) (alert (vl-princ-to-string mainLst)) (mapcar '(lambda (x) (command "_break" (list (car x) (cadr x)) (caddr x))) mainLst) (princ)) Quote
BLOACH85 Posted March 2, 2009 Author Posted March 2, 2009 ok see i guess im really having trouble so how should i put this in my routine? to where it all envokes in one command? Quote
Lee Mac Posted March 2, 2009 Posted March 2, 2009 Just replace the line that asks to select a rectangle with the entity name of your offset rectangle. I.e. the variable rect should be the entity name (ename) of the rectangle you wish to trim inside. - don't worry about deleting the rectangle before running this LISP either. Quote
BLOACH85 Posted March 2, 2009 Author Posted March 2, 2009 Got ya. Thanks Let me see how it works. Quote
Lee Mac Posted March 2, 2009 Posted March 2, 2009 I can't work out how to do it for multiple intersections, or a single intersection... so annoying. My LISP only works if the object intersects the rectangle exactly twice... if only once, it will return and error, and if more than twice, the object won't get trimmed properly.... Quote
BLOACH85 Posted March 2, 2009 Author Posted March 2, 2009 ok Sorry It works fine. But I see that the defun C:test ok now what should i take out of your routine to put into my routine to make it one? Do you see what im saying? Quote
CAB Posted March 2, 2009 Posted March 2, 2009 Take a look at this routine for some ideas: ;;;=======================[ BreakObjects.lsp ]============================== ;;; Author: Copyright© 2006-2008 Charles Alan Butler ;;; Contact @ www.TheSwamp.org ;;; Version: 2.1 Nov. 20,2008 ;;; Purpose: Break All selected objects ;;; permitted objects are lines, lwplines, plines, splines, ;;; ellipse, circles & arcs ;;; ;;; Function c:MyBreak - DCL for selecting the routines ;;; Function c:BreakAll - Break all objects selected with each other ;;; Function c:BreakwObject - Break many objects with a single object ;;; Function c:BreakObject - Break a single object with other objects ;;; Function c:BreakWith - Break selected objects with other selected objects ;;; Function c:BreakTouching - Break objects touching selected objects ;;; Function c:BreakSelected - Break selected objects with any objects that touch it ;;; Revision 1.8 Added Option for Break Gap greater than zero ;;; NEW r1.9 c:BreakWlayer - Break objects with objects on a layer ;;; NEW r1.9 c:BreakWithTouching - Break touching objects with selected objects ;;; Revision 2.0 Fixed a bug when point to break is at the end of object ;;; Revision 2.1 Fixed another bug when point to break is at the end of object ;;; ;;; ;;; Function break_with - main break function called by all others and ;;; returns a list of new enames, see c:BreakAll ;;; for an example of using the return list ;;; ;;; Requirements: objects must have the same z-value ;;; Restrictions: Does not Break objects on locked layers ;;; Returns: none BreakObj21.zip Quote
Lee Mac Posted March 2, 2009 Posted March 2, 2009 Take a look at this routine for some ideas: ;;;=======================[ BreakObjects.lsp ]============================== ;;; Author: Copyright© 2006-2008 Charles Alan Butler ;;; Contact @ www.TheSwamp.org ;;; Version: 2.1 Nov. 20,2008 ;;; Purpose: Break All selected objects ;;; permitted objects are lines, lwplines, plines, splines, ;;; ellipse, circles & arcs ;;; ;;; Function c:MyBreak - DCL for selecting the routines ;;; Function c:BreakAll - Break all objects selected with each other ;;; Function c:BreakwObject - Break many objects with a single object ;;; Function c:BreakObject - Break a single object with other objects ;;; Function c:BreakWith - Break selected objects with other selected objects ;;; Function c:BreakTouching - Break objects touching selected objects ;;; Function c:BreakSelected - Break selected objects with any objects that touch it ;;; Revision 1.8 Added Option for Break Gap greater than zero ;;; NEW r1.9 c:BreakWlayer - Break objects with objects on a layer ;;; NEW r1.9 c:BreakWithTouching - Break touching objects with selected objects ;;; Revision 2.0 Fixed a bug when point to break is at the end of object ;;; Revision 2.1 Fixed another bug when point to break is at the end of object ;;; ;;; ;;; Function break_with - main break function called by all others and ;;; returns a list of new enames, see c:BreakAll ;;; for an example of using the return list ;;; ;;; Requirements: objects must have the same z-value ;;; Restrictions: Does not Break objects on locked layers ;;; Returns: none WOWWW That is one hell of a LISP CAB --- I don't even know where to start... Amazing work Lee Quote
CAB Posted March 2, 2009 Posted March 2, 2009 Thanks, dive right in.. Here is the original, membership required 1 2 Quote
Lee Mac Posted March 3, 2009 Posted March 3, 2009 Ahh, haven't got membership for the Swamp - but may have to consider delving in... looks like a good site. Quote
Husso Posted November 11, 2022 Posted November 11, 2022 On 3/3/2009 at 6:21 AM, CAB said: It's free. I can't join this site because they ask stupid questions. I doubt their seriousness. 3 Quote
mhupp Posted November 12, 2022 Posted November 12, 2022 20 hours ago, Husso said: I can't join this site because they ask stupid questions. I doubt their seriousness. Its to combat spam and its only for like your first 5 or so posts. 1 Quote
BIGAL Posted November 13, 2022 Posted November 13, 2022 I go to the swamp all the time a good site. Quote
