Relative paths in an AutoCAD script (.scr)
As I am using LT 2024, have limited programming skills and need to open and close a number of files I am trying to use a script (.scr) file not a lisp or VBA. The script below does some basic cleaning of files exported from GIS and saves the DXFs as DWGs but I would like this to use relative paths (relative to the working file) so I can avoid changing the paths for each project. Is there a way in can set the paths based on the current open file?
_.open "T:\DXF output\Canopies and Boles.dxf" _.Zoom E _.PURGE all * N _.save LT2018 "T:\DXF output\Canopies and Boles.dwg" Y _.close _.open "T:\DXF output\LabelLines.dxf" _.Zoom E _.PURGE all * N _.save LT2018 "T:\DXF output\LabelLines.dwg" Y _.close _.open "T:\DXF output\LabelText.dxf" _.Zoom E _.PURGE all * N _.save LT2018 "T:\DXF output\LabelText.dwg" Y _.close _.open "T:\DXF output\LabelWhiteOuts.dxf" _.Zoom E _.PURGE all * N _.save LT2018 "T:\DXF output\LabelWhiteOuts.dwg" Y _.close _.open "T:\DXF output\RPAs.dxf" _.Zoom E _.PURGE all * N _.save LT2018 "T:\DXF output\RPAs.dwg" Y _.close _.open "T:\DXF output\Tree Markers.dxf" _.Zoom E _.PURGE all * N _.save LT2018 "T:\DXF output\Tree Markers.dwg" Y _.close _.open "T:\DXF output\Zones Boles Canopies.dxf" _.Zoom E _.PURGE all * N _.save LT2018 "T:\DXF output\Zones Boles Canopies.dwg" Y _.close
I think the script line needs the full file path, what I do is have a control where I build up the functions I want, select the files to work on and press 'go'. In the background this creates a temporary script file writing all the details - functions to run, filepaths and so on but now it works I don't need to worry about that.
I would recommend this from Lee Mac: https://lee-mac.com/scriptwriter.html - though LT2024 is limited with the LISP / VBA functions it can run, it might work. Very simple, as described you build up the routine and it does the hard work of creating the script file. You can save the basic of the routine for later use on a different sat / same set / edit for something else./
Another suggestion as you have lisp in LT 24 I would write the script calling a lisp file. You can load a lisp then call it (dxfspecial dwgname)
Possible script
(load "dxfspecial")
(dxfspecial "Canopies and Boles")
(load "dxfspecial")
(dxfspecial "Canopies and Boles2")
(load "dxfspecial")
(dxfspecial "Canopies and Boles3")
@BIGAL I think your nested approach is probably they way to go, now I have to try and figure out the lisp.
@Lee Mac Many thanks, I'm still not sure where is the best place to go for help with AutoCAD is
For help with the application, I would suggest here at CADTutor; for programming help, I would suggest TheSwamp.org or StackOverflow (though the latter does not have a large CAD community).
Kind of missed my favourite online resource there Lee..... (a great repository for LISP snippets to study and learn from)
Best place to go there are more, forums/autodesk,Augi. But please don't double post at every other forum. It can take a day or two to get a correct answer to your problem.
Always google 1st with "Autocad lisp" on end of search. eg "Extract attributes csv autocad lisp"
