  (setq cdate_val (rtos (getvar "CDATE") 2 6))
  (setq YYYY (substr cdate_val 1 4)
        M    (substr cdate_val 5 2)
        D    (substr cdate_val 7 2)
  (setq dateFolderName (strcat D "-" M "-" YYYY))
  (setq subfolderName (strcat (rtos x 2 2) "-" modtext))
  (setq nestedFolderPath (strcat (getvar "DWGPREFIX") "\\" dateFolderName "\\" subfolderName))
  (princ (strcat "\nNested Folder Path: " nestedFolderPath))
  (if (not (vl-file-directory-p nestedFolderPath)) ; Use vl-file-directory-p for checking directories
        (if (vl-mkdir nestedFolderPath)
            (prompt (strcat "\nCreated folder: " nestedFolderPath))
            (prompt (strcat "\nFailed to create folder: " nestedFolderPath))
      (prompt (strcat "\nFolder already exists: " nestedFolderPath))
  (setq saveFileName (strcat nestedFolderPath "\\" (vl-filename-base (getvar "DWGNAME")) ".dxf"))
  (princ (strcat "\nSave File Path: " saveFileName))
  (if (not(vl-file-copy (getvar "DWGNAME") saveFileName))
    (prompt (strcat "\nError: Unable to save the processed drawing as DXF."))
    (prompt (strcat "\nProcessed drawing saved to: " saveFileName))
Why this code did not work..?
OK help up out a little..... where does the code not work? Or where does the code work until?
Perhaps to help you debug it, add in this:
(princ "\n") ;;add this line
(princ nestedFolderPath) ;; add this line
These 2 parts should be about the middle of the code, if it displays them then it gets that far, if not then the error is before then
A few points -
This code:
Can be shortened to simply:
(setq dateFolderName (menucmd "m=$(edtime,0,dd-mo-yyyy)"))
In this code:
The variables 'x' and 'modtext' are not defined in the code snippet.
In this code:
The DWGPREFIX system variable typically already has a trailing backslash path delimiter, and so this expression is doubling up the path delimiters.
This code:
Does not include a filepath for the source file and will only work if the source file is also a DXF file - you cannot save a DWG file as a DXF file by merely copying it to a new filename.
Sorry for the confusion. Here is my modified code, this code work fine until creating folder after it does not save copy "Error: Unable to save the processed drawing as DXF." give solution for this(Note:my source file also DXF).
 (defun c:createandsave (/ FolderPath dateFolderName subfolderName FolderPath)
 (setq FolderPath (strcat(getvar "DWGPREFIX") dateFolderName))
  (if (not (vl-file-directory-p FolderPath))
    (vl-mkdir FolderPath)
  (vl-mkdir (strcat FolderPath "\\" subfolderName))
  (setq saveFileNamepath (strcat FolderPath "\\" subfolderName))
  (setq saveFileName (strcat (vl-filename-base (getvar "DWGNAME")) ".dxf"))
  (setq saveFile (strcat saveFileName))
  (if (not (vl-file-copy (getvar "DWGNAME") saveFileName))
Thanks in advance..
@ajithkumar.t I recommend you try using the (vla-Saveas) method:
;; Use VlaSaveAs Method
   (setq saveFileName (strcat saveFileNamepath (vl-filename-base (getvar "DWGNAME")) ".dxf"))
   (vla-saveas (vla-get-activedocument (vlax-get-acad-object)) SaveFileName ac2018_dxf)
   (if (findfile SaveFileName)
Also note: you have some incomplete code in your post above:
There is nothing in the function that defines "x" or "modtext" so it errors here.
Edited by pkenewell
  • Like 2
