Calculate diference between 2 dates.
Aftertouch
Hi all,
I am using a LISP to use some automation within the company.
For this case... im using it to convert a Excel file to an VCF-file, to import in phones.
But now.....
I can save the current date with:
(setenv "TELNUMBERS" (rtos (getvar "CDATE") 2 0))
I use this to store the date of the last time the code is executed.
But... i want a detection that the last update has been more that 7 days.
How can i calculate the diference between to dates?
A simpel substraction wont work.... since its date-formated..
So... current date minus the stored date, should be 7 or more... something like
(if ( > (- (rtos (getvar "CDATE") 2 0) (getenv "TELNUMBERS")) 7)
RTOS converts a number to a string and of course you cannot do mathematical operation onto a string.
Maybe convert TELNUMBERS back to a number with ATOF (or ATOI if you want an integer).
CDATE is in seconds I think so you'll want to divide the result by (60 x 60 x 24) 86400 to get days
Use DATE instead of CDATE:
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-CBB24068-1654-4753-BE2E-1D0CE9700411
DATE stores the date value as a Julian date, which simply counts the number of days which have elapsed from a given epoch - as such, you can easily subtract two integer Julian date values to calculate the number of elapsed days between two dates, e.g.:
(< 7 (- (getvar 'date) (atoi (getenv "TELNUMBERS"))))
(assuming you have changed TELNUMBERS to store the DATE value instead of CDATE)
Edited by Lee Mac
  • Like 3
  • Thanks 1
@Lee Mac thanks, seems like that did the trick!
Need to wait a few days to actualy test the code, but the detection seems to do what i want it to do! 🙂
