Aftertouch Posted February 6 Posted February 6 Hi all, I am using a LISP to use some automation within the company. For this case... im using it to convert a Excel file to an VCF-file, to import in phones. But now..... I can save the current date with: (setenv "TELNUMBERS" (rtos (getvar "CDATE") 2 0)) I use this to store the date of the last time the code is executed. But... i want a detection that the last update has been more that 7 days. How can i calculate the diference between to dates? A simpel substraction wont work.... since its date-formated.. So... current date minus the stored date, should be 7 or more... something like (if ( > (- (rtos (getvar "CDATE") 2 0) (getenv "TELNUMBERS")) 7) Quote
Steven P Posted February 6 Posted February 6 RTOS converts a number to a string and of course you cannot do mathematical operation onto a string. Maybe convert TELNUMBERS back to a number with ATOF (or ATOI if you want an integer). CDATE is in seconds I think so you'll want to divide the result by (60 x 60 x 24) 86400 to get days Quote
Lee Mac Posted February 6 Posted February 6 (edited) Use DATE instead of CDATE: https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-CBB24068-1654-4753-BE2E-1D0CE9700411 DATE stores the date value as a Julian date, which simply counts the number of days which have elapsed from a given epoch - as such, you can easily subtract two integer Julian date values to calculate the number of elapsed days between two dates, e.g.: (< 7 (- (getvar 'date) (atoi (getenv "TELNUMBERS")))) (assuming you have changed TELNUMBERS to store the DATE value instead of CDATE) Edited February 6 by Lee Mac 2 1 Quote
Aftertouch Posted February 7 Author Posted February 7 @Lee Mac thanks, seems like that did the trick! Need to wait a few days to actualy test the code, but the detection seems to do what i want it to do! Quote
