make current specific ViewPort
RepCad
Hello everyone,
There are two Viewports in a layout and I want to enable ModelSpace of selected viewport :
  (setq d (vla-get-activedocument (vlax-get-acad-object)))
  (setq vp (car (entsel)))
  (setq vla (vlax-ename->vla-object vp))
  (vla-put-activeviewport d vla)
  (vla-put-mspace d :vlax-true)
It gives error after selecting a viewport :
"Automation Error. Object was erased"
Not sure, but have you tried :
Instead :
This :
(vla-put-activepviewport d vla)
Instead :
This :
Thanks, I try to use CHSPACE command to transfer polyline from model to layout in "activepviewport", but the program stops and returns this message
Set the SOURCE viewport active and press ENTER to continue.:
* This problem just happens when viewport is more than one.
How do I pass this message ?
Here's a quick example with no error checking You need to get the viewport ID then set CVPORT:
(setq e (car (entsel "\nPick a viewport: ")))
(vla-put-mspace (vla-get-ActiveDocument (vlax-get-acad-object)) :vlax-true)
(setvar 'cvport (cdr (assoc 69 (entget e))))
I am not sure why need code to select viewport, if you can see the layout dbl click inside viewport goes straight to model. Then do CHSPACE.
