Drawing Batch Converters
SLW210
I thought I would post the Drawing to DXF batch converter, as well as the others I have  worked on.
All thanks go to the originator and the others that have made modifications and updates, I did very little.
I think some of these need cleaning up, but as far as I can tell, they get the job done.
I had need to convert folders of .dwg's to .dxf's for use on a waterjet, etc. that best use version 2000 so it converts to DXF2000. Easy enough to modify for current version or any other if needed.
;;;<<<<<<<<<<<<<<<<<<<<<<<<<<<<<Modified to Batch Convert AutoCAD® DWG *.dwg into DXF *.dxf>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>|
;;;  Original versions I got from here        |
;;;  https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/batch-convert-dgn-to-dwg/td-p/3237978                |
;;;* DGNIMPORT.LSP - Converts a list of Microstation *.dgn drawings into AutoCAD *.dwg drawings
;;;                  Start command by typing DGNI
;;;                  Make the necessary adjustments to the following variables:
;;;                  tx1 = path and name of a file that holds a list with names for all the *.dgn's to be imported,
;;;                        names of *.dgn drawings may be written without extension, as well as with extension,
;;;                        in plain text format, no return after the last line.
;;;                  tx2 = the path for the input folder, containing the actual *.dgn files to import.
;;;                  tx3 = the path for the output folder, where the drawings converted into *.dwg will be saved,
;;;                        (routine assumes that the *.dwg files do not exist yet)
;;;                  tx4 = name of the drawing model to import
;;;                  The routine reads drawing names from the file given in tx1 line-for-line.
;;;                  In each loop it performs a DGNIMPORT from the folder given as tx2 into the existing AutoCAD drawing,
;;;                  does a Zoom Extends, saves the converted drawing result as *.dwg in the folder given as tx3,
;;;                  and finally restores the drawing to its original state, ready to receive the next DGNIMPORT loop.
;;;                  The DELAY command for 1000 milliseconds (1 second) is needed to provide sufficient separation
;;;                  between the DGNIMPORT and SAVEAS processes (otherwise it starts to mix up drawings).
;;;                  The DGNIMPORT command trips when the name of the *.dgn to be imported contains a comma,
;;;                  I advise to rename drawings having this issue.
;;;                  Written by M. Moolhuysen. Modified by C. Matthews
;;;      Modified by Cage Here https://www.cadtutor.net/forum/topic/78123-batch-convert-acis-sat-to-dwg/#comment-624627
;;;                  This software may not be sold as commercial product or included as part of a commercial product.
;;;               Converts a folder of  AutoCAD® DWG *.dwg drawings into DXF *.dxf drawings (Version 2000)                *
;;;                                        Start command by typing DWG2DXF                                                *
;;;                    Modified by SLW210 A.K.A. Steve Wilson from DGNIMPORT to DWG2DXF 01/31/2024                        *
(defun C:DWG2DXF (/ fil tx1 tx2 tx3 tx4 tx5)
  (princ "Please select input folder. \n")
  (setq tx1 (vl-directory-files (setq tx2 (acet-ui-pickdir)) "*.dwg")) ; Select the folder containing *.dwg files to be imported.
  (princ "Please select output folder. \n")
  (setq tx3 (acet-ui-pickdir)                                             ; Select folder for the *.dxf files to be exported into.
        tx4 "Default"
  (setvar "FILEDIA" 0)
  (foreach tx5 tx1
    (if (wcmatch tx5 "*`.???")
      (setq tx5 (substr tx5 1 (- (strlen tx5) 4)))
    (command "_UNDO" "_MARK"
             "OPEN" "" (strcat tx2 "\\" tx5) tx4 "" ""
             "_ZOOM" "_E"
             "._DELAY" 500
             "_SAVEAS" "D" "V" "2000" "16" (strcat tx3 "\\" tx5 ".dxf") "_N"
    (command "_ERASE" "ALL" "")                ;erases everything on the page after the save
    (command "_.purge" "_all" "" "_no")        ;purges everything so you don't carry it over to the next drawing
    (command "_.purge" "_regapp" "" "_no")
    (command "_QNEW")                          ;opens a new drawing
DWG2DXF.lsp DXF2DWG.lsp DGN to DWG v2.lsp SAT2DWGv2.lsp
  • Thanks 2
