cooldude224 Posted January 30, 2024 Posted January 30, 2024 Hi, I am currently attempting to add an attribute to a large number of unique blocks in a drawing. My current process is to go one by one, manually going into block editor and inserting the attribute. I was wondering if there is a way to automate this process. Is there a way in LISP for me to add the same attribute to all/many blocks at once? I have other attributes in the blocks, could I set the location of the new attribute as an offset from a current one? Any help is much appreciated. Quote
aridzv Posted January 30, 2024 Posted January 30, 2024 see if the attached lisp helps. add_ATT.lsp Aridzv. 1 Quote
cooldude224 Posted January 30, 2024 Author Posted January 30, 2024 (edited) 1 hour ago, aridzv said: see if the attached lisp helps. add_ATT.lsp 1.68 kB · 2 downloads Aridzv. Thank you! This helps a lot, the hardest part I think is going to be getting the attribute in a position on the block that works. I need it to be right above another attribute I have visible. This is a very good starting point though so thanks again for sharing. Edited January 30, 2024 by cooldude224 1 Quote
Emmanuel Delay Posted January 31, 2024 Posted January 31, 2024 (edited) 19 hours ago, aridzv said: see if the attached lisp helps. add_ATT.lsp 1.68 kB · 7 downloads Aridzv. Cool, I saved this one. I just added a couple lines for settings. @cooldude224 My edit should help you with the position of the attribute (defun c:add_ATT (/ ss blk blk-lst atts-lst def AttObj obj2 text_height ip mode align) ;; settings. Feel free to adapt to your needs. ;; Feel free to change the settings from hard coded to user input. See below (setq text_height 2.5) (setq ip (list 0.0 0.0)) ;; insert point in the block (setq default_value "") ;; MODE: ;; (any combination of constants can be used by adding them together): ;; acAttributeModeNormal ;; acAttributeModeInvisible ;; acAttributeModeConstant ;; acAttributeModeVerify ;; acAttributeModePreset (setq mode acAttributeModeNormal) ;; Allignment: ;; acAlignmentLeft / acAlignmentCenter / acAlignmentRight / acAlignmentAligned / acAlignmentMiddle / acAlignmentFit / acAlignmentTopLeft / acAlignmentTopCenter / acAlignmentTopRight / acAlignmentMiddleLeft / acAlignmentMiddleCenter / acAlignmentMiddleRight / acAlignmentBottomLeft / acAlignmentBottomCenter / acAlignmentBottomRight (setq align acAlignmentRight) ;; COMMENT OUT THESE NEXT LINES IF YOU WANT THE HARD CODED SETTINGS (setq text_height (getdist "\nText height: ")) (setq ip (getpoint "\nInsert point: ")) (setq default_value (getstring "\nDefault value: " T)) (vl-load-com) (setq Tag (strcase (getstring "\nSpecify attribute tag: "))) (if (setq ss (ssget '((0 . "INSERT")))) ;change if to while repeats command if you keep selecting things (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) ;makes a list of all entitys by ename in selection set and steps thought them one at a time (setq blk (cdr (assoc 2 (entget e)))) (if (not (vl-position blk blk-lst)) (progn (setq blk-lst (cons blk blk-lst)) (setq obj2 (vlax-ename->vla-object e)) (setq atts-lst nil) ;clear list from last use (if (= (vla-get-hasattributes obj2) :vlax-true) (foreach att (vlax-invoke obj2 'getattributes) (setq atts-lst (cons (strcase (vla-get-tagstring att)) atts-lst)) ;make a list of all Attributs tag names to check rather then checking them all individually ) ;;close foreach ) ;;close if (if (not (member tag atts-lst)) ;checks list for "SYSTEM" could also use vl-position (progn (setq def (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blk)) ;; VL : RetVal = (vla-AddAtribute object Height Mode Prompt InsertionPoint Tag Value) (setq AttObj (vla-addattribute def text_height mode "" (vlax-3D-point ip) TAG default_value)) (vlax-put AttObj 'Alignment align) (vla-move AttObj (vlax-3D-point (list 0.0 0.0)) (vlax-3D-point ip)) (command "_.attsync" "_N" blk) ) ;;close progn ) ;;close if ) ;;close progn ) ;;close if ) ;;close foreach ) ;;close if (princ) ) Edited January 31, 2024 by Emmanuel Delay 3 Quote
