smitaranjan Posted January 29, 2024 Posted January 29, 2024 Is there any chance of matchline automation using lisp in layout? I have attached sample dwg and screenshot of block for matchline. Please help. And thanks in advance. SRS.dwgFetching info... Quote
Danielm103 Posted January 29, 2024 Posted January 29, 2024 maybe a Field with a Diesel expresion $(-,$(getvar,ctab),1) Quote
Emmanuel Delay Posted January 29, 2024 Posted January 29, 2024 Try this, see if you like it. The code will go over all the numeric layouts. For each layout it will ask you an insert point and angle, for 2 blocks, the previous and next... then press enter to go to the next page. If you think this is useful, I can make it a bit more user friendly, feel free to suggest features . Command MLA (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; https://www.lee-mac.com/attributefunctions.html ;; Set Attribute Value - Lee Mac ;; Sets the value of the first attribute with the given tag found within the block, if present. ;; blk - [vla] VLA Block Reference Object ;; tag - [str] Attribute TagString ;; val - [str] Attribute Value ;; Returns: [str] Attribute value if successful, else nil. (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val) ) ) (vlax-invoke blk 'getattributes) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun drawInsert (pt Nme rot) (entmakex (list (cons 0 "INSERT") (cons 2 Nme) (cons 50 rot) (cons 10 pt))) ) (defun c:mla ( / layouts lyt blk ip val) (setq layouts (list)) ;; Obtain list of layout objects (vlax-for lyt (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) ;; skip layouts that don't have a numeric layout name (if (> (atoi (vla-get-name lyt)) 0) (progn (setq layouts (append layouts (list (vla-get-name lyt)))) ) ) ) (setq i 0) (foreach lyt layouts ;; set layout as current (setvar "CLAYOUT" lyt) (if (> i 0) (progn (setq val (nth (- i 1) layouts)) (princ (strcat "\nPrevious Layout, " val ": " )) (setq blk (drawInsert (setq ip (getpoint "\nInsert point: ")) "match_line" (getangle ip "\nAngle: "))) (command "attsync" "_name" "match_line") (LM:vl-setattributevalue (vlax-ename->vla-object blk) "XX" val) )) (if (nth (+ i 1) layouts) (progn (setq val (nth (+ i 1) layouts)) (princ (strcat "\nNext Layout, " val ": " )) (setq blk (drawInsert (setq ip (getpoint "\nInsert point: ")) "match_line2" (getangle ip "\nAngle: "))) (command "attsync" "_name" "match_line2") (LM:vl-setattributevalue (vlax-ename->vla-object blk) "XX" val) )) (getstring "\nPress enter: ") (setq i (+ i 1)) ) ) Quote
smitaranjan Posted January 29, 2024 Author Posted January 29, 2024 On 1/29/2024 at 3:16 PM, Emmanuel Delay said: Try this, see if you like it. The code will go over all the numeric layouts. For each layout it will ask you an insert point and angle, for 2 blocks, the previous and next... then press enter to go to the next page. If you think this is useful, I can make it a bit more user friendly, feel free to suggest features . Command MLA (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; https://www.lee-mac.com/attributefunctions.html ;; Set Attribute Value - Lee Mac ;; Sets the value of the first attribute with the given tag found within the block, if present. ;; blk - [vla] VLA Block Reference Object ;; tag - [str] Attribute TagString ;; val - [str] Attribute Value ;; Returns: [str] Attribute value if successful, else nil. (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val) ) ) (vlax-invoke blk 'getattributes) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun drawInsert (pt Nme rot) (entmakex (list (cons 0 "INSERT") (cons 2 Nme) (cons 50 rot) (cons 10 pt))) ) (defun c:mla ( / layouts lyt blk ip val) (setq layouts (list)) ;; Obtain list of layout objects (vlax-for lyt (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) ;; skip layouts that don't have a numeric layout name (if (> (atoi (vla-get-name lyt)) 0) (progn (setq layouts (append layouts (list (vla-get-name lyt)))) ) ) ) (setq i 0) (foreach lyt layouts ;; set layout as current (setvar "CLAYOUT" lyt) (if (> i 0) (progn (setq val (nth (- i 1) layouts)) (princ (strcat "\nPrevious Layout, " val ": " )) (setq blk (drawInsert (setq ip (getpoint "\nInsert point: ")) "match_line" (getangle ip "\nAngle: "))) (command "attsync" "_name" "match_line") (LM:vl-setattributevalue (vlax-ename->vla-object blk) "XX" val) )) (if (nth (+ i 1) layouts) (progn (setq val (nth (+ i 1) layouts)) (princ (strcat "\nNext Layout, " val ": " )) (setq blk (drawInsert (setq ip (getpoint "\nInsert point: ")) "match_line2" (getangle ip "\nAngle: "))) (command "attsync" "_name" "match_line2") (LM:vl-setattributevalue (vlax-ename->vla-object blk) "XX" val) )) (getstring "\nPress enter: ") (setq i (+ i 1)) ) ) Expand Sure, will check it and let you know Quote
smitaranjan Posted January 29, 2024 Author Posted January 29, 2024 On 1/29/2024 at 3:16 PM, Emmanuel Delay said: Try this, see if you like it. The code will go over all the numeric layouts. For each layout it will ask you an insert point and angle, for 2 blocks, the previous and next... then press enter to go to the next page. If you think this is useful, I can make it a bit more user friendly, feel free to suggest features . Command MLA (vl-load-com) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; https://www.lee-mac.com/attributefunctions.html ;; Set Attribute Value - Lee Mac ;; Sets the value of the first attribute with the given tag found within the block, if present. ;; blk - [vla] VLA Block Reference Object ;; tag - [str] Attribute TagString ;; val - [str] Attribute Value ;; Returns: [str] Attribute value if successful, else nil. (defun LM:vl-setattributevalue ( blk tag val ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (vla-put-textstring att val) val) ) ) (vlax-invoke blk 'getattributes) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun drawInsert (pt Nme rot) (entmakex (list (cons 0 "INSERT") (cons 2 Nme) (cons 50 rot) (cons 10 pt))) ) (defun c:mla ( / layouts lyt blk ip val) (setq layouts (list)) ;; Obtain list of layout objects (vlax-for lyt (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) ;; skip layouts that don't have a numeric layout name (if (> (atoi (vla-get-name lyt)) 0) (progn (setq layouts (append layouts (list (vla-get-name lyt)))) ) ) ) (setq i 0) (foreach lyt layouts ;; set layout as current (setvar "CLAYOUT" lyt) (if (> i 0) (progn (setq val (nth (- i 1) layouts)) (princ (strcat "\nPrevious Layout, " val ": " )) (setq blk (drawInsert (setq ip (getpoint "\nInsert point: ")) "match_line" (getangle ip "\nAngle: "))) (command "attsync" "_name" "match_line") (LM:vl-setattributevalue (vlax-ename->vla-object blk) "XX" val) )) (if (nth (+ i 1) layouts) (progn (setq val (nth (+ i 1) layouts)) (princ (strcat "\nNext Layout, " val ": " )) (setq blk (drawInsert (setq ip (getpoint "\nInsert point: ")) "match_line2" (getangle ip "\nAngle: "))) (command "attsync" "_name" "match_line2") (LM:vl-setattributevalue (vlax-ename->vla-object blk) "XX" val) )) (getstring "\nPress enter: ") (setq i (+ i 1)) ) ) Expand Don't know its working or not, by entering MLA its going to first page and ask angle. Its not working in other print. and its placing next print, as mostly in the dwg, the page are not in order Quote
BIGAL Posted January 30, 2024 Posted January 30, 2024 (edited) Draw rectangs.mp4Fetching info... This task is on a client list I have but a low priority, as I have spent a lot of time automating making layouts it could be something that can be added as part of the procedure. In the process a layout is represented as a rectang so could do a left and right next. For grid style sheets a bit harder as you can have 4 sides touching. I think it was one of your dwg's that I did the grid style layout code. Auto making the layouts. A quick check of the dwg and you need to overlap the rectangs a bit more as you have gaps in your layouts. Maybe click next or prior number then select an edge and it will label in model space, may be a way to auto push through to layout paperspace. Edited January 30, 2024 by BIGAL Quote
smitaranjan Posted January 30, 2024 Author Posted January 30, 2024 On 1/30/2024 at 1:59 AM, BIGAL said: Draw rectangs.mp4 1.41 MB · 0 downloads This task is on a client list I have but a low priority, as I have spent a lot of time automating making layouts it could be something that can be added as part of the procedure. In the process a layout is represented as a rectang so could do a left and right next. For grid style sheets a bit harder as you can have 4 sides touching. I think it was one of your dwg's that I did the grid style layout code. Auto making the layouts. A quick check of the dwg and you need to overlap the rectangs a bit more as you have gaps in your layouts. Maybe click next or prior number then select an edge and it will label in model space, may be a way to auto push through to layout paperspace. Expand Is auto matchline also can be done? Irrespective of their position of viewport...please check the dwg and the placement of matchline in layout and message me personally. Thanks. Quote
BIGAL Posted January 31, 2024 Posted January 31, 2024 (edited) To put match lines in automatically have no idea where to even start, In my walk along a pline yes could be done as you know rectang numbers and which layout is next. For random rectangs all over the place some touching some not as commented earlier. Will think about pick rectang label1, pick label2 then a side as a 1st go, remember something is better than doing it manually. Edited January 31, 2024 by BIGAL Quote
