Jozef13 Posted January 28 Share Posted January 28 Hello, everybody, I have a lot of blocks in my drawing with nested blocks that are in the same layer as the block. In certain cases I need to freeze the nested blocks, and therefore I would need to change the layer of the nested blocks. I need to change the nested blocks whose name contains a specific string. I need this either for selected blocks or all blocks in the drawing. I would be grateful for help as my attempts have been unsuccessful. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted January 28 Share Posted January 28 Try something like this - change the value of the two variables at the top of the code to suit: (defun c:test ( / bln idx lst nla pat ) (setq pat "*block*" nla "NewLayer" pat (strcase pat) ) (if (setq sel (ssget '((0 . "INSERT")))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) bln (cdr (assoc 2 (entget (ssname sel idx)))) ) (if (not (member bln lst)) (progn (setq lst (cons bln lst)) (processblock bln pat nla) ) ) ) ) (princ) ) (defun processblock ( bln str lay / ent ) (if (setq ent (tblobjname "block" bln)) (while (setq ent (entnext ent)) (processobject ent str lay) ) ) ) (defun processobject ( ent str lay / bln enx ) (cond ( (not (setq enx (entget ent)))) ( (/= "INSERT" (cdr (assoc 0 enx)))) ( (not (wcmatch (setq bln (strcase (cdr (assoc 2 enx)))) str)) (processblock bln str lay) ) ( (entmod (subst (cons 8 lay) (assoc 8 enx) enx)) (processblock bln str lay) ) ) ) (princ) 1 3 Quote Link to comment Share on other sites More sharing options...
rlx Posted January 29 Share Posted January 29 as always you make it look so easy master Lee 2 Quote Link to comment Share on other sites More sharing options...
Jozef13 Posted January 29 Author Share Posted January 29 Perfect as always. Thank you very much. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted January 29 Share Posted January 29 Thanks both - glad it helps. 1 Quote Link to comment Share on other sites More sharing options...
