Lisp to change layer of nested block inside block
Hello, everybody,
I have a lot of blocks in my drawing with nested blocks that are in the same layer as the block. In certain cases I need to freeze the nested blocks, and therefore I would need to change the layer of the nested blocks. I need to change the nested blocks whose name contains a specific string. I need this either for selected blocks or all blocks in the drawing. I would be grateful for help as my attempts have been unsuccessful.
Try something like this - change the value of the two variables at the top of the code to suit:
(defun c:test ( / bln idx lst nla pat )
    (setq pat "*block*"
          nla "NewLayer"
          pat (strcase pat)
    (if (setq sel (ssget '((0 . "INSERT"))))
        (repeat (setq idx (sslength sel))
            (setq idx (1- idx)
                  bln (cdr (assoc 2 (entget (ssname sel idx))))
            (if (not (member bln lst))
                    (setq lst (cons bln lst))
                    (processblock bln pat nla)
(defun processblock ( bln str lay / ent )
    (if (setq ent (tblobjname "block" bln))
        (while (setq ent (entnext ent))
            (processobject ent str lay)
(defun processobject ( ent str lay / bln enx )
    (cond
        (   (not (setq enx (entget ent))))
        (   (/= "INSERT" (cdr (assoc 0 enx))))
        (   (not (wcmatch (setq bln (strcase (cdr (assoc 2 enx)))) str))
            (processblock bln str lay)
        (   (entmod (subst (cons 8 lay) (assoc 8 enx) enx))
  • Thanks 4
as always you make it look so easy master Lee 🤓
  • Like 2
