How do you draw arc in AutoCAD 2014 classic workspace from A to B with radius of the arc is 500 as shown on attached image?
Please tell me step-by-step. Thank you
Edited by basty
Start the arc command. It will ask for the start point. Give it the coordinates of point A.
You then have the option to provide the center point or the end point. Center is the default, so you have to type E for End. Give it the coordinates of point B.
You then have the option to provide the center point or some other parameter. In this case it's the radius, so you type R. Type 500. The arc will appear.
Apart from drawing a line, this is one of the easiest tasks in AutoCAD. If you're having trouble with this, maybe drafting is not for you.
