Mythicalmage Posted January 24, 2024 Posted January 24, 2024 I already have drawings in modelspace set at different scales. I need to add dim lines to a plate. The question is is there a lisp routine or does cad have built in a command to switch a dim style based on an existing dim in the dwg? again I am dimming in modelspace. Quote
Emmanuel Delay Posted January 25, 2024 Posted January 25, 2024 16 hours ago, Mythicalmage said: I already have drawings in modelspace set at different scales. I need to add dim lines to a plate. The question is is there a lisp routine or does cad have built in a command to switch a dim style based on an existing dim in the dwg? again I am dimming in modelspace. Can you give a few examples? A few dwg names and which style corresponds to each ? Quote
