LISP for creating new Line with a sum of numbers of length
Ivy Tr
I don't know if it makes sense. I wonder if there is a way to create a line that will ask for a total length and then you able to add multiple lengths in it, for example adding 5'+2'+3' then the line will be create as 10' automatically). Right now I just calculate  a total length myself and make a line with it.  It would save lots of time if I can just add them in while creating a new line. Thank you.
Edited by Ivy Tr
Welcome in the forum, Ivy Tr!
I think it is possible, but how do you wish to draw the line? Maybe you wish to click the start point, an other click to define the direction, and next enter those numbers? Or if you wish less user inputs, just enter those numbers end let the program to draw a horizontal line from the origin?
Please give us more data.
Just in case you didn't know the "direct distance entry" trick, try this:
Start the line command (say press L followed by <enter> or <space>). AutoCAD prompts you for the first point. Click on the screen to enter it. When AutoCAD prompts you for the next point, move the mouse to the desired place in order to define the direction (OSNAP is useful at this point!), but don't click. Leave the mouse in that place and enter from the keyboard (+ 5 2 3)<enter>
That should draw the line you are after. From there you can continue the line command, meaning to draw the next line, or press <enter> again to exit.
Please note that you must enter the plus sign first, a space, and next enter all the numbers to be added, separated by a space.
It is not so complicated... :)
Try this and let me know if it works for you.
;;; Creates a fixed line based on different given distances
;;; By Isaac A 20240124
;;; https://www.cadtutor.net/forum/topic/79256-lisp-for-creating-new-line-with-a-sum-of-numbers-of-length/?_fromLogin=1
(defun c:fl (/ a b c d dw e oe)
  (vl-load-com)
  (vla-startundomark (setq dw (vla-get-activedocument (vlax-get-acad-object))))
  (setq oe (getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (setq a (getpoint "\nPick the starting point")
        b (getpoint "\Pick a second point for the direction" a)
        c (angle a b)
  (initget 2)
  (if (not (= (setq d (getreal "\nType the starting distance: ")) (or 0 nil)))
        (while (setq e (getreal "\nType the next distance: "))
           (setq d (+ d e))
        (entmake (list '(0 . "LINE")
                        (cons 10 a)
                        (cons 11 (mapcar '+ a (list (* d (cos c)) (* d (sin c)))))
                       '(8  . "test_lines")
                       '(62 . 1)
  (setvar 'cmdecho oe)
  (vla-endundomark dw)
This code creates a line with a total length of: 1 distance + 2 distance + 3 distance + ...
Is it possible to do this with a polyline so that these part are visible?
Yes, this is possible, although no one think a lisp is needed because you can do this using the polyline command, but just to keep programming here it is my version of it
;;; Creates a fixed lwpolyline based on different given distances
;;; By Isaac A 20240128
(defun c:fpl (/ a b c d dw e f l oe)
  (vl-load-com)
  (setvar 'cmdecho 0)
        c (angle a b)
        f (list a)
  (initget 2)
		    f (append f (list (polar a c d))) ) (or 0 nil)))
        (initget 6)
           (setq d (+ d e)
        (entmakex (append (list '(0   . "LWPOLYLINE")
                                '(100 . "AcDbEntity")
                                '(410 . "Model")
                                '(8   . "Test_lwpolylines")
                                '(62  . 40)
                                '(100 . "AcDbPolyline")
                                 (cons 90 (length f))
                          (mapcar (function (lambda (l) (cons 10 l))) f)
  • Like 2
@Isaac26a thanks!  👏
In this code, it is very valuable that the polyline preserves the angle,
if you draw a polyline in the usual way, the angle is not supported...
Using a while maybe
(setq tot 0.0)
(while (setq d (getreal "\nEnter distance Enter to exit "))
(setq tot (+ tot d))
 this is exactly what I need, it work great with decimal number, I just wish it works with fraction number as I mainly work with feets and inches.
  (vl-load-com)
  (setvar 'cmdecho 0)
        c (angle a b)
  (initget 2)
           (setq d (+ d e))
                        (cons 10 a)
                       '(8  . "test_lines")
                       '(62 . 1)
this works for me. Thanks Isaac
  • 3 weeks later...
@Isaac26a
you can add to your lisp the ability to make sections of the same polyline in different colors,
for example, red 1 and blue 5?
