Ivy Tr Posted January 23 Share Posted January 23 (edited) I don't know if it makes sense. I wonder if there is a way to create a line that will ask for a total length and then you able to add multiple lengths in it, for example adding 5'+2'+3' then the line will be create as 10' automatically). Right now I just calculate a total length myself and make a line with it. It would save lots of time if I can just add them in while creating a new line. Thank you. Edited January 23 by Ivy Tr Quote Link to comment Share on other sites More sharing options...
fuccaro Posted January 24 Share Posted January 24 Welcome in the forum, Ivy Tr! I think it is possible, but how do you wish to draw the line? Maybe you wish to click the start point, an other click to define the direction, and next enter those numbers? Or if you wish less user inputs, just enter those numbers end let the program to draw a horizontal line from the origin? Please give us more data. 1 Quote Link to comment Share on other sites More sharing options...
fuccaro Posted January 24 Share Posted January 24 Just in case you didn't know the "direct distance entry" trick, try this: Start the line command (say press L followed by <enter> or <space>). AutoCAD prompts you for the first point. Click on the screen to enter it. When AutoCAD prompts you for the next point, move the mouse to the desired place in order to define the direction (OSNAP is useful at this point!), but don't click. Leave the mouse in that place and enter from the keyboard (+ 5 2 3)<enter> That should draw the line you are after. From there you can continue the line command, meaning to draw the next line, or press <enter> again to exit. Please note that you must enter the plus sign first, a space, and next enter all the numbers to be added, separated by a space. It is not so complicated... 1 Quote Link to comment Share on other sites More sharing options...
Isaac26a Posted January 24 Share Posted January 24 Try this and let me know if it works for you. ;;; Creates a fixed line based on different given distances ;;; By Isaac A 20240124 ;;; https://www.cadtutor.net/forum/topic/79256-lisp-for-creating-new-line-with-a-sum-of-numbers-of-length/?_fromLogin=1 (defun c:fl (/ a b c d dw e oe) (vl-load-com) (vla-startundomark (setq dw (vla-get-activedocument (vlax-get-acad-object)))) (setq oe (getvar 'cmdecho)) (setvar 'cmdecho 0) (setq a (getpoint "\nPick the starting point") b (getpoint "\Pick a second point for the direction" a) c (angle a b) ) (initget 2) (if (not (= (setq d (getreal "\nType the starting distance: ")) (or 0 nil))) (progn (while (setq e (getreal "\nType the next distance: ")) (setq d (+ d e)) ) (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 (mapcar '+ a (list (* d (cos c)) (* d (sin c))))) '(8 . "test_lines") '(62 . 1) ) ) ) ) (setvar 'cmdecho oe) (vla-endundomark dw) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 28 Share Posted January 28 On 1/24/2024 at 8:48 PM, Isaac26a said: ;;; Creates a fixed line based on different given distances This code creates a line with a total length of: 1 distance + 2 distance + 3 distance + ... Is it possible to do this with a polyline so that these part are visible? Quote Link to comment Share on other sites More sharing options...
Isaac26a Posted January 28 Share Posted January 28 Yes, this is possible, although no one think a lisp is needed because you can do this using the polyline command, but just to keep programming here it is my version of it ;;; Creates a fixed lwpolyline based on different given distances ;;; By Isaac A 20240128 ;;; https://www.cadtutor.net/forum/topic/79256-lisp-for-creating-new-line-with-a-sum-of-numbers-of-length/ (defun c:fpl (/ a b c d dw e f l oe) (vl-load-com) (vla-startundomark (setq dw (vla-get-activedocument (vlax-get-acad-object)))) (setq oe (getvar 'cmdecho)) (setvar 'cmdecho 0) (setq a (getpoint "\nPick the starting point") b (getpoint "\Pick a second point for the direction" a) c (angle a b) f (list a) ) (initget 2) (if (not (= (setq d (getreal "\nType the starting distance: ") f (append f (list (polar a c d))) ) (or 0 nil))) (progn (initget 6) (while (setq e (getreal "\nType the next distance: ")) (setq d (+ d e) f (append f (list (polar a c d))) ) ) (entmakex (append (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(410 . "Model") '(8 . "Test_lwpolylines") '(62 . 40) '(100 . "AcDbPolyline") (cons 90 (length f)) ) (mapcar (function (lambda (l) (cons 10 l))) f) ) ) ) ) (setvar 'cmdecho oe) (vla-endundomark dw) (princ) ) 2 Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 28 Share Posted January 28 51 minutes ago, Isaac26a said: ;;; Creates a fixed lwpolyline based on different given distances @Isaac26a thanks! In this code, it is very valuable that the polyline preserves the angle, if you draw a polyline in the usual way, the angle is not supported... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 30 Share Posted January 30 Using a while maybe (setq tot 0.0) (while (setq d (getreal "\nEnter distance Enter to exit ")) (setq tot (+ tot d)) ) Quote Link to comment Share on other sites More sharing options...
Ivy Tr Posted January 31 Author Share Posted January 31 On 1/24/2024 at 5:29 AM, fuccaro said: Just in case you didn't know the "direct distance entry" trick, try this: Start the line command (say press L followed by <enter> or <space>). AutoCAD prompts you for the first point. Click on the screen to enter it. When AutoCAD prompts you for the next point, move the mouse to the desired place in order to define the direction (OSNAP is useful at this point!), but don't click. Leave the mouse in that place and enter from the keyboard (+ 5 2 3)<enter> That should draw the line you are after. From there you can continue the line command, meaning to draw the next line, or press <enter> again to exit. Please note that you must enter the plus sign first, a space, and next enter all the numbers to be added, separated by a space. It is not so complicated... this is exactly what I need, it work great with decimal number, I just wish it works with fraction number as I mainly work with feets and inches. Quote Link to comment Share on other sites More sharing options...
Ivy Tr Posted January 31 Author Share Posted January 31 On 1/24/2024 at 10:48 AM, Isaac26a said: Try this and let me know if it works for you. ;;; Creates a fixed line based on different given distances ;;; By Isaac A 20240124 ;;; https://www.cadtutor.net/forum/topic/79256-lisp-for-creating-new-line-with-a-sum-of-numbers-of-length/?_fromLogin=1 (defun c:fl (/ a b c d dw e oe) (vl-load-com) (vla-startundomark (setq dw (vla-get-activedocument (vlax-get-acad-object)))) (setq oe (getvar 'cmdecho)) (setvar 'cmdecho 0) (setq a (getpoint "\nPick the starting point") b (getpoint "\Pick a second point for the direction" a) c (angle a b) ) (initget 2) (if (not (= (setq d (getreal "\nType the starting distance: ")) (or 0 nil))) (progn (while (setq e (getreal "\nType the next distance: ")) (setq d (+ d e)) ) (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 (mapcar '+ a (list (* d (cos c)) (* d (sin c))))) '(8 . "test_lines") '(62 . 1) ) ) ) ) (setvar 'cmdecho oe) (vla-endundomark dw) (princ) ) this works for me. Thanks Isaac Quote Link to comment Share on other sites More sharing options...
Nikon Posted February 16 Share Posted February 16 On 1/28/2024 at 9:09 PM, Isaac26a said: ;;; Creates a fixed lwpolyline based on different given distances ;;; By Isaac A 20240128 @Isaac26a you can add to your lisp the ability to make sections of the same polyline in different colors, for example, red 1 and blue 5? Quote Link to comment Share on other sites More sharing options...
