EnM4st3r Posted January 23, 2024 Posted January 23, 2024 Hi, I want to create a temporary dcl file using vl-filename-mktemp. The Question is, does that function leave behind a file if I dont delete it within my lisp? While testing i ran it a few time without deleting it afterwards, so idk if i have a load of dcl files on my drive now.. If it does leave a file behind, any ideas where that files might be located? Quote
Steven P Posted January 23, 2024 Posted January 23, 2024 Unless you tell it to be deleted it will remain. If you delete the file via LISP and the user cancels the routine before that delete line then the temporary files will remain of course (suppose you can delete them in error trapping if you want). I'll tend to specify explicitly which folder to save the dcl file to (windows temporary folder, which you -should- be able to clear out whenever you want without thinking...should....). If you don't specify a DCL file name one will be assigned so I will also tend to specify a unique filename for each DCL box I want, each time it is created it will over write pervious renditions of it. If the user cancels the routine and a file name was assigned then it is possible to have a lot of DCL files in the temporary folder, specify the file name and you should only have one... and then you don't need to worry so much about deleting the file (OK it is lazy programming to leave stuff behind in the temp folder) Quote
EnM4st3r Posted January 23, 2024 Author Posted January 23, 2024 (edited) Thank you, found it in C:\Users\user\AppData\Local\Temp there's also a lot of other files there.. Edited January 23, 2024 by EnM4st3r Quote
BIGAL Posted January 30, 2024 Posted January 30, 2024 (edited) I set my temp file to d:\acadtemp much shorter and easier to find. Re temp files SV$, AC$hsdkjdsksj DWL1 & dwl2 to mention a few. The Vlmktmp are meant to be auto removed on closing CAD. Anyway here is cleanup.lsp, you may be horrified how much junk you have in that temp directory.Multi toggles.lsp save multi toggles to a support path as its auto loaded. cleanup temp.lsp Edited January 30, 2024 by BIGAL 1 Quote
EnM4st3r Posted January 30, 2024 Author Posted January 30, 2024 Thanks @BIGAL, that cleanup lisp is nice. Also yes, there is much Junk in that temp directory.. Cleaned it last Week from around 30gb and now there is around 14gb again. So it fills quite fast to that amount. Maybe a good idea to clean it completely once every few months. Quote
BIGAL Posted January 30, 2024 Posted January 30, 2024 (edited) Let me know if extra file types need to be added. Yes were I worked the guys never cleaned up may wonder why disk is full. I will see if can add how much disk retrieved. Edited January 30, 2024 by BIGAL Quote
dexus Posted January 30, 2024 Posted January 30, 2024 (edited) 10 hours ago, BIGAL said: I set my temp file to d:\acadtemp much shorter and easier to find. Re temp files SV$, AC$hsdkjdsksj DWL1 & dwl2 to mention a few. The Vlmktmp are meant to be auto removed on closing CAD. Anyway here is cleanup.lsp, you may be horrified how much junk you have in that temp directory.Multi toggles.lsp save multi toggles to a support path as its auto loaded. cleanup temp.lsp 2 kB · 5 downloads Nice idea. I tried to add a filetype, but during that process I made a more compact version. It is using LM:listbox found at https://www.lee-mac.com/listbox.html ; clean up temp directory.. (defun cleanuptemp ( / *files* pre types ans val) (setq *files* (vla-get-files (vla-get-preferences (vlax-get-Acad-object)))) (setq pre (vla-get-TempFilePath *files*)) (mapcar 'princ (list "\n " (chr 149) " Your temp directory is: " pre)) (setq types (mapcar (function (lambda (typ / files) (setq files (vl-directory-files pre (car typ))) (list (strcat (if (= files nil) "0" (rtos (length files) 2 0)) " " (cadr typ)) files) )) '( ("*.BAK" "BAK's") ("*.sv$" "SV$'s") ("*.dwl*" "DWL's") ("*.AC$" "AC$'s") ("*.log" "Logfile's") ("*.dcl" "DCL's") ("*.txt" "TXT's") ("*.scr" "SCR's") ("*.dmp" "DMP's") ) ) ) (if (setq ans (LM:listbox "Pick to delete" (mapcar 'car types) 3)) (foreach val ans (foreach filename (cadr (nth val types)) (if (vl-file-delete (strcat pre filename)) (mapcar 'princ (list "\n " (chr 149) " Deleted: " filename)) ) ) ) ) (princ) ) (cleanuptemp) Edited January 30, 2024 by dexus Quote
BIGAL Posted January 31, 2024 Posted January 31, 2024 Yes can be done as list box, a suggestion. ) (if (setq ans (LM:listbox "Pick to delete" (mapcar 'car types) 3)) ) (if (not LM:listbox)(load "leemaclistbox.lsp")) (if (setq ans (LM:listbox "Pick to delete" (mapcar 'car types) 3)) Will try out (vl-file-size filename) so should display how much deleted. Quote
