leonucadomi Posted January 16 Posted January 16 hello all: I am writing a code that generates a solid e11 and a solid e22 then I subtract e11 with e22 and I have as a result a third solid. I use "entlast" to call it e3 I would like to obtain the volume of that new solid created. Can somebody help me? thanks here my code. (defun c:test (/) (setq e1 (entsel)) (setq e2 (entsel)) (command "_extrude" e1 "" 1000 "" ) (setq e11 (entlast)) (command "_extrude" e2 "" 1000 "" ) (setq e22 (entlast)) (command "__subtract" e11 "" e22 "") (command "_erase" e1 e2 "") (setq e3 (entlast)) ) ;_ defun Quote
Steven P Posted January 16 Posted January 16 If you use: (setq vol (* (vlax-get Obj 'volume) )) where obj is the vla-object name of your solid - not the entity name, you need a conversion which is: (setq obj (vlax-ename->vla-object e3)) (where e3 is as above) (defun c:test (/) (setq e1 (entsel)) (setq e2 (entsel)) (command "_extrude" e1 "" 1000 "" ) (setq e11 (entlast)) (command "_extrude" e2 "" 1000 "" ) (setq e22 (entlast)) (command "__subtract" e11 "" e22 "") (command "_erase" e1 e2 "") (setq e3 (entlast)) (setq obj (vlax-ename->vla-object e3)) (setq vol (* (vlax-get Obj 'volume) )) ) 1 Quote
Tsuky Posted January 16 Posted January 16 You can also use field (does not appear in the list of the dialog box)?!?! (vl-load-com) (defun c:Label_Volume ( / js htx AcDoc Space n obj ename pt alpha nw_obj) (princ "\nSelect solid.") (while (null (setq js (ssget (list '(0 . "3DSOLID") (cons 67 (if (eq (getvar "CVPORT") 1) 1 0)) (cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model")) ) ) ) ) (princ "\nAren't solid!") ) (initget 6) (setq htx (getdist (getvar "VIEWCTR") (strcat "\nGive the height of the text <" (rtos (getvar "TEXTSIZE")) ">: "))) (if htx (setvar "TEXTSIZE" htx)) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (vla-startundomark AcDoc) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) ename (vlax-ename->vla-object obj) ) (initget 1) (redraw obj 3) (setq pt (getpoint "\nInsertion point?: ") alpha 0.0 nw_obj (vla-addMtext Space (vlax-3d-point pt) 0.0 (strcat "{\\fArial|b0|i0|c0|p34;" "%<\\AcObjProp.16.2 Object(%<\\_ObjId " (itoa (vla-get-ObjectID ename)) ">%).Volume \\f \"%lu2%pr2%ps[V=,m³]\">%" ) ) ) (redraw obj 4) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'Layer 'Rotation) (list 5 (getvar "TEXTSIZE") 5 pt (getvar "CLAYER") alpha) ) ) (vla-endundomark AcDoc) (prin1) ) Quote
