M_Simons Posted February 25, 2009 Posted February 25, 2009 Hello, Does anyone know how to modify the way AutoCAD Electrical populates the reference field of source/destination arrows? For instance when you insert a source/destination arrow AutoCAD automatically populates the reference field with "From" and "To". The appearance of "From" and "To" on a drawing is inconsistent with my company's standard. Is there a way to change this so that AutoCAD does not insert the "From" "To" at all, but will still insert the cross-references I have defined in the project? Or is there a way to modify the text AutoCAD inserts in place of "From", "To"? I am able to manually delete the from and to, however this seems to defeat the purpose of ACADE -Matt Quote
MFish Posted March 11, 2009 Posted March 11, 2009 Hello, Does anyone know how to modify the way AutoCAD Electrical populates the reference field of source/destination arrows? For instance when you insert a source/destination arrow AutoCAD automatically populates the reference field with "From" and "To". The appearance of "From" and "To" on a drawing is inconsistent with my company's standard. Is there a way to change this so that AutoCAD does not insert the "From" "To" at all, but will still insert the cross-references I have defined in the project? Or is there a way to modify the text AutoCAD inserts in place of "From", "To"? I am able to manually delete the from and to, however this seems to defeat the purpose of ACADE -Matt If you go into the original block for the destination arrow (HA4D3.DWG) and for the signal arrow (HA4S1.DWG) You can double click the XREF attribute and modify the PROMPT line. Note: the above mentioned DWG's are the Signal Arrows I use. If you use different ones, just double click on one that you have used in the past and it will tell you what block name it is saved under. If there is anything else, or if that is not what you were trying to change just let us know. :wink: Quote
M_Simons Posted March 16, 2009 Author Posted March 16, 2009 Yes, that is exactly what I did to resolve the issue. Thanks! Quote
MFish Posted March 16, 2009 Posted March 16, 2009 Yes, that is exactly what I did to resolve the issue. Thanks! I am glad I could help :wink: Quote
