Nguyen Tai Posted January 12, 2024 Posted January 12, 2024 Hi everyone, I want to create an AutoCAD Lisp with the following content: 1. Select objects. 2. Move the selected objects to the center of any bounding box. Thank you for reading and helping ! Quote
BIGAL Posted January 13, 2024 Posted January 13, 2024 (edited) So the select objects, then Geom center for plines ? Problems with which object is object1 as selecting objects is via drawn order unless you pick pick pick. Pretty easy pick obj1 place on center1. Post a before and after dwg. Edited January 13, 2024 by BIGAL Quote
