Add text to string by 'TextString (adding functionality in existing short lisp)
Hi
I have short lisp, writed by someone.
It read clicked polyline lenght and put result to clicked attribute in block.
I would like to add on end string a sign "m".
I tried "strcat", but it not worked.
Someone help me ?
(defun c:KT_dlugosc ( / poly att)
  (while
    (and
      (setq poly (ssget "_+.:S:E" '((0 . "*LINE"))))
      (setq att (car (nentsel "\nSelect Attribute")))
      (eq "AcDbAttribute"
	  (vla-get-objectname (setq att (vlax-ename->vla-object att)))
     (vlax-put att
	       'TextString
	       (rtos (vlax-curve-getDistAtParam
		       (setq poly (ssname poly 0))
		       (vlax-curve-getEndParam poly)
		     2 0
  )(princ)
Hello Dszlapka, welcome in the forum!
I am in vacation right now, I can't test it, but the "strcat" method should work.
  (while
    (and
      (eq "AcDbAttribute"
     (vlax-put att
	       'TextString
	       (strcat (rtos (vlax-curve-getDistAtParam
		     2 0
	       ) "m")
  )(princ)
 Please try this code and post a feed-back. Post the error message you get, for sure someone will be able to fix it!
  • Thanks 1
Thanks a lot. It works as I wanted.
I see it was very simple, but not for me :) I used "strcat" incorrectly.
Have a nice holiday.
