Hello,
I have a block named "A". I can copy this block in a defined position and rotation with the following code:
(command "-insert" "A" "1,1" 1 1 0)
Many forums say that is also possibile to insert automatically the content of the attribute (NAME) using this code:
(command "-insert" "A" "1,1" 1 1 0 "cir")
In this case the attribute is NAME and its content is cir.
If i try to run this code, AutoCAD doesn't insert automatically the content, it asks to type it manually, as you can see in the screenshot. How can I solve?
Thank you!
There are 2 variables that control this action ATTREQ & ATTDIA.
ATTREQ will allow or stop input of attributes.
ATTDIA controls the dcl display
You home work is have a look at help, HINT the values are 0 or 1 using (setvar 'ATTREQ x)
Oh, never heard of ATTREQ.  This could be useful
