ilenia Posted January 8 Share Posted January 8 Hello, I have a block named "A". I can copy this block in a defined position and rotation with the following code: (command "-insert" "A" "1,1" 1 1 0) Many forums say that is also possibile to insert automatically the content of the attribute (NAME) using this code: (command "-insert" "A" "1,1" 1 1 0 "cir") In this case the attribute is NAME and its content is cir. If i try to run this code, AutoCAD doesn't insert automatically the content, it asks to type it manually, as you can see in the screenshot. How can I solve? Thank you! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 8 Share Posted January 8 There are 2 variables that control this action ATTREQ & ATTDIA. ATTREQ will allow or stop input of attributes. ATTDIA controls the dcl display You home work is have a look at help, HINT the values are 0 or 1 using (setvar 'ATTREQ x) 1 Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted January 10 Share Posted January 10 Oh, never heard of ATTREQ. This could be useful Quote Link to comment Share on other sites More sharing options...
