Emmanuel Delay Posted January 8, 2024 Posted January 8, 2024 II got Autocad 2024 now. nentsel selection of a a polyline used to return the line on which you clicked. Now it seems to return the whole polyline. So nentsel is just entsel. What happenend? Is this a new Auocad 2024 bug (I'm not calling this a feature, feel free to disagree)? Any obvious solution? Quote
lastknownuser Posted January 8, 2024 Posted January 8, 2024 Don't have 2024, but did you check if the polyline is 3D? It doesn't work for regular pline if I'm not mistaken Quote
lastknownuser Posted January 8, 2024 Posted January 8, 2024 10 minutes ago, Emmanuel Delay said: It's not 3D polylines https://docs.autodesk.com/ACD/2011/ENU/filesALR/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-699d.htm "When the selected object is not complex (that is, not a 3D polyline or block), nentsel returns the same information as entsel" Quote
Steven P Posted January 8, 2024 Posted January 8, 2024 Just checking, on my installation (2022), nentsel and entsel on a LW Polyline returns the same, nentsel and entsel return different results on a 3d polyline Quote
Emmanuel Delay Posted January 8, 2024 Author Posted January 8, 2024 I guess I'll have to write my own nentsel for polylines. Quote
Emmanuel Delay Posted January 8, 2024 Author Posted January 8, 2024 nentselp does the same as nentsel Quote
Emmanuel Delay Posted January 9, 2024 Author Posted January 9, 2024 (edited) Something like this. Extra properties to be added as needed. (vl-load-com) (defun drawLine (p1 p2) (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2)))) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; http://www.lee-mac.com/round.html ;; Round Up - Lee Mac ;; Rounds 'n' up to the nearest 'm' (defun LM:roundup ( n m ) ((lambda ( r ) (cond ((equal 0.0 r 1e-8) n) ((< n 0) (- n r)) ((+ n (- m r))))) (rem n m)) ) ;; Round Down - Lee Mac ;; Rounds 'n' down to the nearest 'm' (defun LM:rounddown ( n m ) ((lambda ( r ) (cond ((equal 0.0 r 1e-8) n) ((< n 0) (- n r m)) ((- n r)))) (rem n m)) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; This function allows the user to select a segment of polyline. ;; The function returns the segment as though it were a line. As if the polyline was exploded. (defun nentselpl ( / res sel type sel_pt pl par start_ end_) (setq sel (entsel "\nSelect ployline: ")) (setq pl (car sel)) (setq type (cdr (assoc 0 (entget pl)))) (if (wcmatch type "*POLYLINE") (progn (setq sel_pt (cadr sel)) (setq sel_pt (vlax-curve-getClosestPointTo (vlax-ename->vla-object pl) sel_pt)) ;; parameter -> this tells you the index of the segment. And where on the segment the point is (setq par (vlax-curve-getparamatpoint pl sel_pt)) ;; (vlax-ename->vla-object pl) ;; start point of the segment (setq start_ (vlax-curve-getPointAtParam (vlax-ename->vla-object pl) (LM:rounddown par 1.0))) (setq end_ (vlax-curve-getPointAtParam (vlax-ename->vla-object pl) (LM:roundup par 1.0))) (setq res (list (cons 10 start_) (cons 11 end_) (cons 8 (cdr (assoc 8 (entget pl)))) ;; layer ;; ... add extra properties if you wish )) ) nil ) res ) ;; TEST function (defun c:nentselpl ( / sel) (setq sel (nentselpl)) (princ sel) (drawLine (cdr (assoc 10 sel)) (cdr (assoc 11 sel)) ) (princ) ) Edited January 9, 2024 by Emmanuel Delay 2 Quote
