Dynamic hiccups in my polyline (gah!)
First time asking for help here, please be patient.  Forgive the simple crudeness of my code I'm new to LISP.
I have this code I've been working on and it almost works right.
(defun C:FLATCALC ()
(SETQ COVERSTYLE (GETINT "\CoverStyle *  1-RECT  2-ROUNDED  3-CORNER (1-3) :"))
(SETQ MWIDTH (GETREAL "\Measured Width :"))
(SETQ MPROJ (GETREAL "\Measured Projection :"))
(if (= 1 COVERSTYLE) (SETQ RWIDTH MWIDTH))
(if (= 1 COVERSTYLE) (SETQ RPROJ MPROJ))
(if (= 1 COVERSTYLE) (SETQ RCHORD MWIDTH))
(if (= 1 COVERSTYLE) (SETQ MRAD 2))
(if (= 1 COVERSTYLE) (SETQ INSET 0))
(if (= 2 COVERSTYLE) (SETQ MCHORD (GETREAL "\Measured Chord :")))
(if (= 2 COVERSTYLE) (SETQ MRAD (GETREAL "\Measured Radius :")))
(if (= 2 COVERSTYLE) (SETQ RWIDTH (+ MWIDTH 1.5)))
(if (= 2 COVERSTYLE) (SETQ RPROJ (+ MPROJ 0.75)))
(if (= 2 COVERSTYLE) (SETQ RCHORD (+ MCHORD 1.5)))
(if (= 2 COVERSTYLE) (SETQ OFFSET (- MWIDTH MCHORD)))
(if (= 2 COVERSTYLE) (SETQ INSET (/ OFFSET 2)))
(if (= 3 COVERSTYLE) (SETQ CSIDE (GETINT "\Corner Side 1-LEFT  2 RIGHT  (1-2) :")))
(if (= 3 COVERSTYLE) (SETQ RWIDTH MWIDTH))
(if (= 3 COVERSTYLE) (SETQ RPROJ MPROJ))
(if (= 3 COVERSTYLE) (SETQ RCHORD MWIDTH))
(if (= 3 COVERSTYLE) (SETQ INSET 0))
(SETQ p0 (list 0 0))
(SETQ p1 (list 0 RWIDTH))
(SETQ p2 (list (- RPROJ MRAD) (- RWIDTH INSET)))
(SETQ p3 (list RPROJ (- RWIDTH (+ MRAD INSET))))
(SETQ p4 (list RPROJ (+ MRAD INSET)))
(SETQ p5 (list (- RPROJ MRAD) INSET))
(setq c1 (list 48.125 RWIDTH))
(command "_pline" p0 p1 p2 p3 p4 p5 "C")
(setq RRAD MRAD)
(if (= 3 COVERSTYLE) (if (= CSIDE 1) (SETQ RRAD 1)))
(setvar "filletrad" RRAD)
(command "_fillet" p2 p4)
(setq LRAD MRAD)
(if (= 3 COVERSTYLE) (if (= CSIDE 2) (SETQ LRAD 1)))
(setvar "filletrad" LRAD)
(command "_fillet" p4 p0)
(if (< RPROJ 48) (command "_line" p1 c1 ""))
One issue is the failure to run the first time after loading... it draws the first segment of the poly and chokes.  I delete that segment and re-run and it goes.  I am using (load "flatcalc") then typing flatcalc to make the program run.   to make sure its running right I use these test numbers...  coverstyle - 2   measured width - 62   measured projection - 40  measured chord - 56 and radius - 15.   This draws correctly.
I am making a polyline based on some conditional user input and adding 2 fillets and possibly a line.  When I select coverstyle 1 or 3 (a rectangular poly) the p5 variable sets correctly but does not draw correctly.  This blows me away.   Before adding the conditionals for coverstyle 3 this was not the case.    I can see all the variables are setting as they should,  no nils.
Any help would be very appreciated.   TIA!
