mhy3sx Posted January 4, 2024 Posted January 4, 2024 Hi and happy new year to all. I use some Image menus with slides. I update them from time to time and all the times I have to write again and again in the cmd this commads incase to create the list of the slides. cd /d C:\menu\lines\dir *.sld /b > mylist C:\menu\lines\slidelib lines < mylist I try to convert them to a *.bat to do all the job automatic but is not working. Can any one Help? @echo off cd /d C:\menu\lines dir *.sld /b > mylist slidelib lines < mylist Thanks Quote
BIGAL Posted January 4, 2024 Posted January 4, 2024 You may need to add path to slidelib , what you have matches the instructions. Quote
mhy3sx Posted January 5, 2024 Author Posted January 5, 2024 Hi BIGAL. The slidelib is allready in lines folder. I don''t Know why is not working !!!! Thanks Quote
mhy3sx Posted January 6, 2024 Author Posted January 6, 2024 I try this but is not working @echo off cd /d C:\menu\lines dir *.sld /b > mylist C:\menu\lines\slidelib.exe lines < mylist Quote
mhy3sx Posted January 7, 2024 Author Posted January 7, 2024 Hi BIGAL. Can you post your code because is not working for me !!!!! Thanks Quote
mhy3sx Posted January 8, 2024 Author Posted January 8, 2024 (edited) Thanks Edited January 8, 2024 by mhy3sx Quote
BIGAL Posted January 8, 2024 Posted January 8, 2024 Did it fix never used /d I did not spend hours finding about /d Quote
mhy3sx Posted March 2, 2024 Author Posted March 2, 2024 No work like this @echo off chcp 65001 cd C:\mypath\myfolder dir *.sld /b > mylist C:\mypath\myfolder\slidelib.exe myfolder < mylist Quote
