pls...I am looking for lisp draw simple stairs in plan just one runner ( with fast input treads number only and with fixed length of 0.3 m for each) in metric units ,and I will make the calculation of staircase..thanks for anyone who has helping me out..
stair1.dwg
Edited by adeladel
The only issue with stairs is the rise / run check, to do what you want need the Z difference as well, here in AUS there is standards to be met, just drawing the line work use array and done.
So given your dwg would need the total Z and distance the 0.3 may need to be changed to meet code.
I calculate the riser by myself its easy , no need to Z difference ..its 2D a simple stair one runner..as example if I need draw 5 treads only or 10 treads ... and thanks for your reply.. i update the attachment to show what I need exactly..
Edited by adeladel
