Nikon Posted January 1 Share Posted January 1 (edited) Happy New Year to all How can I put the text in the command string without copying and pasting, but just specify the desired text and it will appear on the command string, or perhaps by dragging the text to the command string? Edited January 7 by Nikon Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 1 Share Posted January 1 Look at entsel and entget. Something like this, untested, no CAD today to check for typos (setq MyEnt (entget (car (entsel "Select text:"))) ; Select an object ;; can do some checking here that the selected object is text (setq MyText (cdr (assoc 1 (MyEnt)))) ; get the text string from the object (princ MyText) I assume you want to do more than just display the text in the command line, but these 3 lines above will do that, add to a LISP routine or make your own based around this maybe Note that very long text strings (for example in mtext)(over 256 characters?) the text is stored in another variable in the entity description, something to be aware of 1 Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 1 Author Share Posted January 1 (edited) @Steven P Thank you and happy new year I have little knowledge of programming, I do not know what to do with these lines of code. My task is as follows: I have a list (text) with lisp names in the file dwg (_autoload "11") (_autoload "12") . . . . . . . . . . . . . (_autoload "16") I point to the desired text and it is inserted into the command string, I press "enter" and lisp loads and starts working... The difficulty is that the text does not need to be highlighted, just point at it. Edited January 7 by Nikon Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 1 Share Posted January 1 Time to start learning a little..... (this is a good resource, http://www.lee-mac.com/tutorials.html ) The snippets of code will do what you want but a learning point for you to make that into a LISP perhaps? Use the link above and other examples we've given you to see if you can make something up. Pretty much for that create the first row '(defun .....' and the last row ')', saved in a file. For the next part you will need to select the text rather than pointing the mouse at the text (right clicks), for now though have a go at making the above into a LISP, post what you make up below and I am happy to guide you to the next steps of what you want to do. However it sounds like what you want is a menu rather than selecting texts in the drawing? An Alternative is a bit more work and a pop-up dialog with the commands listed that you can select 1 Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 1 Author Share Posted January 1 (edited) On 01.01.2024 at 16:25, Steven P said: However it sounds like what you want is a menu rather than selecting texts in the drawing? An Alternative is a bit more work and a pop-up dialog with the commands listed that you can select No, it's just about pointing to the text from the dwg drawing. Edited January 7 by Nikon Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 1 Share Posted January 1 Yes, that is possible using something called grread, but as the AutoCAD help suggests that is 'for advanced functions and generally "get" functions should be used' (something like that) - in other words AutoDesk are recommending to use another method. It is generally faster to use one type of input, all mouse (point + click) or all keyboard (type in the LISP name) rather than hover, check you have text and the correct text highlighted, press enter. If you want a list on the screen to select then I'd recommend point + click - which follows on from my answer above. Maybe a description of your ultimate aims would help, part questions get part answers. What we might suggest as an output might not be compatible with what you want to do next. Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 1 Author Share Posted January 1 Probably, the game is not worth the candle?.. Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 1 Share Posted January 1 No it is very possible to do, just trickier and most will not, preferring the simpler ways to do things. Simpler ways have more example code and descriptions to learn from, and you will get more help using them. Compare the 2 codes below. Simpler first: ;;Example, select text string traditionally. 6 lines of code (defun c:GrabText ( / MyEnt MyText) (setq MyEnt (entget (car (entsel "Select text:")))) ; Select an object (setq MyText (cdr (assoc 1 MyEnt))) ; get the text string from the object (princ MyText) (princ) ) More complex. ;;Example, hover over text, press enter or space to select. 67 lines of code (defun c:GrabText ( / MyValue MyEnt EndLoop grsel sela lw pt MyText LastText sel ) (princ (setq Msg "Select text")) (setq MyValue "") (setq MyEnt (list)) (setq EndLoop "No") (while (= EndLoop "No") (setq grsel (grread nil 9 2)) (setq sela (car grsel)) (if (= sela 5) ; Highlight on hover (progn (if lw (redraw lw 4) ) ;Remove any highlight (if (and (setq pt (cadr grsel) ) (setq lw (ssget pt)) (setq lw (ssname lw 0)) (if (or (= LastText (cdr (assoc 1 (entget lw)))) (= (cdr (assoc 1 (entget lw))) nil) ) ; endor (redraw lw 3) (progn (setq MyText (cdr (assoc 1 (entget lw)))) (setq LastText MyText) (princ "\n") (princ LastText) (redraw lw 3) ) ; end progn ) ; end if ) ; end and (redraw lw 3) ) ; end if ) ; end progn ) ; end if (if (= sela 2) ; text entry only "Enter" or "Space" (progn (setq sel (nth 1 grsel)) (if (= (type sel) 'LIST) (progn (setq MyEnt (nentselp sel)) (if (= nil MyEnt) (Princ "\nMissed! Try again.\nSelect text: ") (setq EndLoop "Yes") ) ; end if (redraw lw 4) ; remember to (redraw xyz 3) in originating code to keep highlight (setq sel nil) ) ; end progn (progn (if (= sel 13) ; enter (progn (setq EndLoop "Yes") ) ; end progn ) ; end if (if (= sel 32) ; space (progn (setq EndLoop "Yes") ) ; end progn ) ; end if ) ; end progn ) ; end if list )) ; end progn ; end if text / mouse entry ) ; end while (princ "\nThanks. Selected text: ") (princ MyText) (princ) ) I'll let you decide which one to you want to study and understand first. 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 1 Share Posted January 1 To run after select. (princ MyText) replace with (vl-cmdf mytext) Why would you have your run lisp programs as text ? Just make a menu if you can use notepad you can make a menu. 1 1 1 Quote Link to comment Share on other sites More sharing options...
Romero Posted January 2 Share Posted January 2 Some time ago on this forum, I used a context menu to insert predefined texts. On that occasion, I received the help of the talented @Lee Mac to develop the necessary code. The code is basically a menu (list) that contains the specific texts that you want to insert. If you want to change the text, simply right click and choose the option with the desired text. The height of the inserted text automatically adjusts to the current text style. In the event that the style does not have a defined height, the user will be prompted to enter a specific height. You can find the original post where Lee Mac gave me help at this link. Here you have the code adapted to your needs. I hope this is helpful to you. (defun c:ITEXT ( / IR_*error* IR_dch IR_dcl IR_des IR_hgt IR_idx IR_ins IR_lst IR_sty ) (defun IR_*error* ( msg ) (if (< 0 IR_dch) (unload_dialog IR_dch)) (if (= 'file (type IR_des)) (close IR_des)) (if (and (= 'str (type IR_dcl)) (setq IR_dcl (findfile IR_dcl))) (vl-file-delete IR_dcl)) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))) (princ (strcat "\nError: " msg)) ) (princ) ) (setq IR_lst '( "_autoload \"11\"" "_autoload \"12\"" "_autoload \"13\"" "_autoload \"14\"" "_autoload \"15\"" "_autoload \"16\"" ) ) (setq IR_sty (getvar 'textstyle) IR_hgt (cdr (assoc 40 (tblsearch "style" IR_sty))) ) (if (zerop IR_hgt) (progn (initget 6) (setq IR_hgt (cond ((getdist (strcat "\nAltura de texto <" (rtos (getvar 'textsize)) ">: "))) ((getvar 'textsize)))) ) ) (if (and (setq IR_dcl (vl-filename-mktemp nil nil ".dcl")) (setq IR_des (open IR_dcl "w")) (foreach str '( "txt : dialog" "{" " key = \"dcl\"; spacer;" " : list_box" " {" " key = \"lst\";" " width = 40;" " height = 20;" " fixed_width = true;" " fixed_height = true;" " allow_accept = true;" " }" " ok_cancel;" "}" ) (write-line str IR_des) ) (not (setq IR_des (close IR_des))) (< 0 (setq IR_dch (load_dialog IR_dcl))) ) (while (not (cond ( (not (new_dialog "txt" IR_dch)) (princ "\nDialog could not be loaded.") ) ( (progn (set_tile "dcl" "Select Text") (start_list "lst") (foreach itm IR_lst (add_list itm)) (end_list) (set_tile "lst" (cond (IR_idx) ((setq IR_idx "0")))) (action_tile "lst" "(setq IR_idx $value)") (zerop (start_dialog)) ) ) ( (while (setq IR_ins (getpoint "\rSpecify text insertion point <back>: ")) (entmake (list '(000 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") '(008 . "_TEXTOS") (cons 007 IR_sty) (cons 040 IR_hgt) (cons 010 (trans IR_ins 1 0)) (cons 001 (nth (atoi IR_idx) IR_lst)) (cons 011 (getvar 'ucsxdir)) (cons 210 (trans '(0.0 0.0 1.0) 1 0 t)) ) ) ) (redraw) ) ) ) ) (princ "\nUnable to write & load DCL file.") ) (IR_*error* nil) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 2 Author Share Posted January 2 (edited) @Steven P @BIGAL @Romero Thank you very much for your participation and advice. I will try and learn... Edited January 2 by Nikon Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 2 Author Share Posted January 2 10 hours ago, Steven P said: ;;Example, select text string traditionally. 6 lines of code (defun c:GrabText ( / MyEnt MyText) (setq MyEnt (entget (car (entsel "Select text:")))) ; Select an object (setq MyText (cdr (assoc 1 MyEnt))) ; get the text string from the object (princ MyText) (princ) ) This is close to my task, the text appears on the command string, but the lisp does not load. Why is that? 1 hour ago, Romero said: (defun c:ITEXT ( / IR_*error* IR_dch IR_dcl IR_des IR_hgt IR_idx IR_ins IR_lst IR_sty ) This code inserts the selected text into the drawing, but I already have my list in dwg. Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 2 Author Share Posted January 2 10 hours ago, Steven P said: ;;Example, hover over text, press enter or space to select. 67 lines of code (defun c:GrabText ( / MyValue MyEnt EndLoop grsel sela lw pt MyText LastText sel ) (princ (setq Msg "Select text")) @Steven P what should I add to the code for the command (selected text) to load? Quote Link to comment Share on other sites More sharing options...
Romero Posted January 2 Share Posted January 2 @nikon I apologize as it seems I misinterpreted your request. Now I understand that what you really need is to be able to select some text to be displayed on the command line, is that correct? Here is a starting point that I hope will be useful to you. (defun c:t2cl () (setq IR_ent (car (entsel "\nSelect text: "))) (if IR_ent (progn (setq IR_texto (cdr (assoc 1 (entget IR_ent)))) (princ (strcat "\n" IR_texto)) ) (princ "\nno text selected.") ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 2 Author Share Posted January 2 (edited) 30 minutes ago, Romero said: (defun c:t2cl () (setq IR_ent (car (entsel "\nSelect text: "))) @Romero thanks the command appears on the command string, but lisp does not load, as if the command is transparent or ghostly... command: T2CL Select text: (_autoload "11") Edited January 2 by Nikon Quote Link to comment Share on other sites More sharing options...
Romero Posted January 2 Share Posted January 2 (edited) 22 minutes ago, Nikon said: @Romero gracias, el comando aparece en la cadena de comando, pero lisp no se carga, como si el comando fuera transparente o fantasmal ... comando: T2CL Seleccionar texto: (_autoload "11") In AutoLISP, there is no direct way to monitor or control the command line in real time to automatically detect and execute a command if it matches specific text. AutoLISP runs sequentially and lacks the ability to interact with the AutoCAD command line in real time. The 'princ' function is used to print text to the command line, but it does not have the ability to detect or execute commands based on what is displayed on the command line. Automatic detection of commands entered on the command line and their subsequent execution is not possible directly through AutoLISP. To achieve similar functionality, it would be necessary to use another programming language or the API provided by AutoCAD, such as the .NET API or the use of event-triggered AutoLISP. These offer broader interaction capabilities and control over commands entered on the AutoCAD command line. Unfortunately, I lack knowledge on how to achieve this. Edited January 2 by Romero 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted January 2 Share Posted January 2 (edited) Assuming I've understood what you're looking to achieve, you could potentially use the sendcommand method to accomplish this, i.e.: (defun c:ctext ( / ent enx str ) (while (not (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect command text: "))) (cond ( (= 7 (getvar 'errno)) (prompt "\nMissed, try again.") ) ( (null ent)) ( (not (wcmatch (cdr (assoc 0 (setq enx (entget ent)))) "*TEXT")) (prompt "\nThe selected object is not text or mtext.") ) ( (setq str (cdr (assoc 1 enx)))) ) ) ) ) (if str (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) (strcat str "\n"))) (princ) ) (vl-load-com) (princ) Edited January 2 by Lee Mac 5 Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 2 Author Share Posted January 2 38 minutes ago, Lee Mac said: Assuming I've understood what you're looking to achieve, you could potentially use the sendcommand method to accomplish this, i.e.: @Lee Mac Thank you very much! Magic has happened! It works the way I wanted it to! The text gets into the command string and the lisp is loaded. It's incredible! Your work is very valuable. Good luck in the new year! 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted January 2 Share Posted January 2 23 hours ago, BIGAL said: To run after select. (princ MyText) replace with (vl-cmdf mytext) Why would you have your run lisp programs as text ? Just make a menu if you can use notepad you can make a menu. That wasn't working and I think you'd have to use send command like Lee Macs code above or perhaps something including 'read' to make it run? Quote Link to comment Share on other sites More sharing options...
Nikon Posted January 3 Author Share Posted January 3 (edited) I use the Lee "сtext" command to load Lisp of this type (_autoload "11"). 11 is the name of the command. At the end of the code with the extension (.lsp), I add (c:11), and the list is loaded and the command is immediately active. How can I write a string (_autoload "11") for files with the extension (.fas) and (.vlx), since these files cannot be edited and. I cannot add them at the end of the code (C:11). For simple loading (_autoload "dim text_bgmask") it works, but the command is not active, it needs to be additionally entered into the command string. I'm trying to add (_autoload "dimtext_bgmask" '("dimtext_bgmask")) or (_autoload "dimtext_bgmask" (c:dimtext_bgmask)) But it doesn't work, messages appear on the command string: ;error: too many arguments ;error: invalid function: "dim text_bgmask" Please advise me how to write the string correctly (_autoload... dimtext_bgmask.fas Edited January 7 by Nikon Quote Link to comment Share on other sites More sharing options...
