Engineer_Yasser Posted December 31, 2023 Posted December 31, 2023 (edited)   I need to add an option to Mirror The Block While Using The Lisp when press ( m ) button  I do it manually by adding or removing minus ( - ) to ( Scale X ) value while selecting the block   ;;;¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,;;; ;;;ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,¤؛°`°؛¤;;; ;; ;; ;; ;; ;; --=={ Block Align }==-- ;; ;; ;; ;; Will align a block to a CurveObject [Arc,Line,Polyline,Ellipse,etc], with ;; ;; controllable offset and perpendicularity. ;; ;; ;; ;; User is prompted for block specification, block will be inserted if not ;; ;; selected. User can also specify whether block should be rotated to suit ;; ;; readability. ;; ;; ;; ;;=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=;; ;; ;; ;; FUNCTION SYNTAX: BA ;; ;; ;; ;;=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=;; ;; ;; ;; AUTHOR: ;; ;; ;; ;; Copyright © Lee McDonnell, April 2010. All Rights Reserved. ;; ;; ;; ;; { Contact: Lee Mac @ TheSwamp.org, CADTutor.net } ;; ;; ;; ;;=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=;; ;; ;; ;; VERSION: ;; ;; ;; ;; ّ 1.0 ~¤~ 29th April 2010 ~¤~ ؛ First Release ;; ;;...............................................................................;; ;; ّ 1.1 ~¤~ 30th April 2010 ~¤~ ؛ Added Scale option ;; ;;...............................................................................;; ;; ;; ;;=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=;; ;; ;; ;;;¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,;;; ;;;ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,¤؛°`°؛¤;;; (defun c:ba nil (c:BLK_Align)) (defun c:BLK_Align ( / *error* B! BBOX CURV DOC LLST OBJ OLDPOS OLDROT SEL SPC ) (vl-load-com) ;; Lee Mac ~ 29.04.10 (defun *error* ( msg ) (and lLst (LayerRestore lLst)) (and OldPos (vla-put-insertionPoint obj OldPos)) (and OldRot (vla-put-Rotation obj OldRot)) (and b! (not (vlax-erased-p Obj)) (vl-catch-all-apply (function vla-delete) (list obj) ) ) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (setq spc (if (or (eq AcModelSpace (vla-get-ActiveSpace (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))))) (eq :vlax-true (vla-get-MSpace doc))) (vla-get-ModelSpace doc) (vla-get-PaperSpace doc)) lLst (LayerUnlock)) (while (progn (setq Sel (SelectionOrText (strcat "\nSpecify Block to Align" (if (eq "" (getvar 'INSNAME)) ": " (strcat " <" (getvar 'INSNAME) "> : ") ) ) 2 ) ) (cond ( (vl-consp sel) (if (not (= 4 (length sel))) (princ "\n** Invalid Object Selected **") (not (setq obj (vlax-ename->vla-object (car (last sel) ) ) ) ) ) ) ( (eq 'STR (type sel)) (if (eq "" sel) (setq sel (getvar 'INSNAME))) (if (not (or (tblsearch "BLOCK" sel) (setq sel (findfile (strcat sel ".dwg"))))) (princ "\n** Block not Found **") (if (and (setq scl (cond ( (getreal "\nSpecify Block Scale <1.0> : ") ) ( 1.0 ) ) ) (not (vl-catch-all-error-p (setq Obj (vl-catch-all-apply (function vla-InsertBlock) (list spc (vlax-3D-point (getvar 'VIEWCTR)) sel scl scl scl 0.) ) ) ) ) ) (progn (setvar 'INSNAME (vl-filename-base sel)) (not (setq b! (not (vla-put-Visible Obj :vlax-false) ) ) ) ) (princ "\n** Error Inserting Block **") ) ) ) ) ) ) (if (and Obj (setq Curv (CurveIfFoo isCurveObject "\nSelect Curve: ") ) ) (progn (initget "Yes No") (setq Red (not (eq "No" (getkword "\nMake Block Readable? [Y/N] <Yes> : ")))) (setq bbox (GetBoundingBox Obj)) (or b! (and (setq OldPos (vla-get-InsertionPoint Obj)) (setq OldRot (vla-get-Rotation Obj)))) (and b! (vla-put-Visible Obj :vlax-true)) (setq b! (not (AlignObjtoCurve Obj Curv (/ (- (cadadr bbox) (cadar bbox)) 2.) Red ) ) ) ) ) (LayerRestore lLst) (princ) ) (defun isCurveObject ( ent ) (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-curve-getEndParam) (list ent))))) (defun GetBoundingBox ( obj / ll ur ) (if (vlax-method-applicable-p obj 'GetBoundingBox) (progn (vla-getBoundingBox obj 'll 'ur) (mapcar (function vlax-safearray->list) (list ll ur)) ) ) ) (defun CurveifFoo ( foo str / sel ent ) (while (progn (setq sel (entsel str)) (cond ( (vl-consp sel) (if (not (foo (setq ent (car sel)))) (princ "\n** Invalid Object Selected **")))))) ent) (defun SelectionOrText ( str cur ) (and str (princ str)) ( (lambda ( result / gr code data ) (while (progn (setq gr (grread t 13 cur) code (car gr) data (cadr gr)) (cond ( (and (= 3 code) (listp data)) (setq result (nentselp data)) nil ) ( (= 2 code) (cond ( (<= 32 data 126) (setq result (strcat result (princ (chr data)))) ) ( (= 13 data) nil ) ( (and (= 8 data) (< 0 (strlen result))) (setq result (substr result 1 (1- (strlen result)))) (princ (vl-list->string '(8 32 8))) ) ( t ) ) ) ( (= 25 code) nil ) ( t ) ) ) ) result ) "" ) ) (defun AlignObjToCurve ( obj ent o r / msg gr code data pt cAng lAng ) (or *Mac$Per* (setq *Mac$Per* (/ pi 2.))) (or *Mac$Off* (setq *Mac$Off* 1.)) (setq msg (princ "\n[+/-] for offset, [P]erpendicularity toggle, <Exit>")) (while (progn (setq gr (grread 't 15 0) code (car gr) data (cadr gr)) (cond ( (and (= 5 code) (listp data)) (setq data (trans data 1 0)) (setq pt (vlax-curve-getClosestPointto ent data) cAng (angle pt data) lAng (+ cAng *Mac$Per*)) (and R (setq lAng (MakeReadable lAng))) (vla-put-InsertionPoint Obj (vlax-3D-point (polar pt cAng (* o *Mac$Off*)) ) ) (vla-put-Rotation Obj lAng) t ) ( (= 2 code) (cond ( (vl-position data '(43 61)) (setq *Mac$Off* (+ *Mac$Off* 0.1)) ) ( (= 45 data) (setq *Mac$Off* (- *Mac$Off* 0.1)) ) ( (vl-position data '(80 112)) (setq *Mac$Per* (- (/ pi 2.) *Mac$Per*)) ) ( (vl-position data '(13 32)) nil ) ( t ) ) ) ( (and (= 3 code) (listp data)) (setq data (trans data 1 0)) (setq pt (vlax-curve-getClosestPointto ent data) cAng (angle pt data) lAng (+ cAng *Mac$Per*)) (and R (setq lAng (MakeReadable lAng))) (vla-put-InsertionPoint Obj (vlax-3D-point (polar pt cAng (* o *Mac$Off*)) ) ) (vla-put-Rotation Obj lAng) nil ) ( (= 25 code) nil ) ( t ) ) ) ) data ) (defun MakeReadable ( a ) (cond ( (and (> a (/ pi 2)) (<= a pi)) (- a pi) ) ( (and (> a pi) (<= a (/ (* 3 pi) 2))) (+ a pi) ) ( a ) ) ) (defun LayerUnlock ( / lock ) (vlax-for layer (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object) ) ) (if (eq :vlax-true (vla-get-Lock layer)) (progn (setq lock (cons layer lock)) (vla-put-lock layer :vlax-false) ) ) ) lock ) (defun LayerRestore ( lst ) (mapcar (function (lambda ( layer ) (vla-put-lock layer :vlax-true) ) ) lst ) ) (princ "\nّ¤؛°`°؛¤ّ BAlign.lsp ~ Copyright © by Lee McDonnell ّ¤؛°`°؛¤ّ") (princ "\n ~¤~ ...Type \"BLK_Align\" or \"BA\" to Invoke... ~¤~ ") (princ) ;;;¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,;;; ;; ;; ;; End of Program Code ;; ;; ;; ;;;ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,ّ¤؛°`°؛¤ّ,¸¸,¤؛°`°؛¤;;;  LM_BlockAlign.lsp Edited January 2, 2024 by Engineer_Yasser Quote
Engineer_Yasser Posted January 1, 2024 Author Posted January 1, 2024 (edited) @Lee Mac   Edited January 2, 2024 by Engineer_Yasser Quote
Steven P Posted January 1, 2024 Posted January 1, 2024 (edited) You might need to appreciate that it is new years day, considered replies might be a bit slow and overnight last night were never going to happen.... Â Â Â However the basic line to change I think is this, changing one of the 'scl' (scl scl scl : x y z scales) Â (vl-catch-all-apply (function vla-InsertBlock) (list spc (vlax-3D-point (getvar 'VIEWCTR)) sel scl scl scl 0.) ) Â Then do some nice stuff around it to work out whether to mirror the block or not, perhaps a new LISP name (BAM maybe?) or user interface to ask mirror or not. Â Might need to also consider if the insert point has to move with mirroring it to keep the alignment the same... but the basic change is make the x scale negative in the line above Edited January 1, 2024 by Steven P Quote
Engineer_Yasser Posted January 1, 2024 Author Posted January 1, 2024  Sorry , Happy New Year For Everyone   1 Quote
Engineer_Yasser Posted January 1, 2024 Author Posted January 1, 2024 3 hours ago, Steven P said: You might need to appreciate that it is new years day, considered replies might be a bit slow and overnight last night were never going to happen....    However the basic line to change I think is this, changing one of the 'scl' (scl scl scl : x y z scales)  (vl-catch-all-apply (function vla-InsertBlock) (list spc (vlax-3D-point (getvar 'VIEWCTR)) sel scl scl scl 0.) )  Then do some nice stuff around it to work out whether to mirror the block or not, perhaps a new LISP name (BAM maybe?) or user interface to ask mirror or not.  Might need to also consider if the insert point has to move with mirroring it to keep the alignment the same... but the basic change is make the x scale negative in the line above   Thanks for replying .. what I need is to change the ( Scale X ) value from negative to positive or from positive to negative as shown in the pic by pressing (m) button while using the lisp.  The lisp aligns the Block dynamically to curve and there is an option to perpendicular or offset the block ... I need to add mirror option as I explained in the pic   Quote
Engineer_Yasser Posted January 2, 2024 Author Posted January 2, 2024 I Got it .. just add this line to ( AlignObjToCurve ) Function in the code  ( (vl-position data '(77 109)) (entmod (subst (cons 41 (- (cdr (assoc 41 (entget (vlax-vla-object->ename obj)))))) (assoc 41 (entget (vlax-vla-object->ename obj))) (entget (vlax-vla-object->ename obj)))) )  1 Quote
