Rhinoceros 3.0
Has anyone else used rhinoceros 3.0? A friend of mine told me to get rhinoceros 3.0 to facilate the process of designing my car. He feels Rhinoceros has much more user friendly commands for 3d modeling. If so i have not found them.. What i have found it useful for though is joining lines in different planes. A task pedit will not do in Autocad. Another trick i have learned is how to easily subtract shapes form mesh. Well not exactly.. this is how it is done draw the outline for the mesh with half of the shapes you want inside of the mesh on one of the edges (the top half of the shape or the bottom half of the shape) and draw the other mesh with the other half of the shape and place the meshes side by side now i realize the mesh you wanted in one piece is in two pieces now but save it and open it in rhinoceros and join the two meshes.
(it doesnt matter how many different meshes you have to draw in autocad and piece together to get the shape you want subtracted because you can join them all in rhinoceros along with polylines)
I have Rhino 2.0 and I have to say that it does ROCK! I am also trying to learn it byt drawing a car but I am so used to AutoCAD that I find that I am having trouble. I have seen tutorials and such on Rhino that shows that it can do what you want. Do a web search for Rhino tutorials and you should find more than you could ever use. It is hard to beat for it's price.
Audi TT Tutorial
http://www.ifrance.com/LMD/html/audittUS.html
Shelby Cobra
http://www.geocities.com/SiliconValley/Horizon/4419/cardemo.html
New VW Beetle
http://www.suurland.com/portfolio_stills_newbeetle_a-and-r.htm
Lamborghini Miura
http://www.3dvault.net/Wyatt/one.html
Hope these are new for you..
  • 3 years later...
Rhinoceros is a good solution.
But you can use Genesis Integral Object Designer.
Genesis IOD is surface and solid modeler with a powerfull GuideGen command
that is not available in Rhinoceros.
If you are an Autocad user it will we easy to use for you, because it is an ARX
plugin for Autocad 2008 and 2007.
regards..
  • 10 months later...
do you have a link for this Genesis Integral Object Designer
I use Rhinoceros but version 4.0, looking forward to v5 and i will upgrade
  • 8 months later...
The link of GENESIS Integral Object Designer is:
www right-toolbox com
Regards
