Nikon Posted December 30, 2023 Author Posted December 30, 2023 @BIGAL Thanks for the help. 6 hours ago, BIGAL said: (defun c:11 ( / ..... ..... .. ) (c:11) As I understand it, lisps with this ending (c:11) should not be in the startup, otherwise (if there are 10-20 pieces. - they will all immediately start executing this commands) there will be confusion... or am I wrong in my assumption? Quote
Steven P Posted December 30, 2023 Posted December 30, 2023 That's right, if there is a stand alone line of code in the LISP (not enclosed by (defun ...... ) then that will be executed as the LISP loads. If the file only contains a single LISP then loading the file on demand as discussed above will run the LISP. You can delete this or comment it out (with ;; )in the file you have saved if it is more convenient. For example, I have a start up LISP file and in this there are lines, outside of a function, that sets the system to my preferences, so it is the same each time I load a drawing rather than whatever it was last time I closed one, this functionality has its uses. 1 Quote
Nikon Posted January 1 Author Posted January 1 (edited) Happy New Year to all Is it possible to slightly change lisp "11" so that the line at an angle (minus) (anglevalue) does not go under the X axis? (defun c:11 (/ p0 ang dist) (defun 11error (errormsg /) (setvar "SNAPANG" old_snapang) ; reset variables (setvar "ORTHOMODE" old_orthomode) (setq *error* temperr) ; reset *error* (prompt "\nFunction Canelled.") ) (vl-load-com) (setq p0 (getpoint "Pick the first point >") ang (angtof (rtos (getreal "Enter angle >")) 0) ) (setq Old_snapang (getvar "SNAPANG")) ; to record what it was, might not be 0 (setq old_orthomode (getvar "ORTHOMODE")) (setq temperr *error*) ;store *error* ; can wait till here to set error function, after recording old variables (setq *error* 11error) (setvar "SNAPANG" ang) (setvar "ORTHOMODE" 1) (setq dist (distance p0 (getpoint p0 "Pick a second point >"))) (setvar "SNAPANG" Old_Snapang) ; moved this here, seto to old value (no assumption what it was) (setvar "ORTHOMODE" old_orthomode) (entmakex (list (cons 0 "LINE") (cons 10 p0) (cons 11 (polar p0 ang dist)))) (setq *error* temperr) ; reset error (princ) ) Edited January 7 by Nikon Quote
1958 Posted January 1 Posted January 1 2 hours ago, Nikon said: Happy New Year to all Is it possible to slightly change lisp "11" so that the line at an angle (minus) (anglevalue) does not go under the X axis? Prohibition of entering a negative value (defun c:11 (/ p0 ang dist) (defun 11error (errormsg /) (setvar "SNAPANG" old_snapang) ; reset variables (setvar "ORTHOMODE" old_orthomode) (setq *error* temperr) ; reset *error* (prompt "\nFunction Canelled.") ) (vl-load-com) (setq p0 (getpeint "Pick the first point >")) (initget 4) ; Entering negative numbers is not allowed (setq ang (angtof (rtos (getreal "Enter angle >")) 0)) (setq Old_snapang (getvar "SNAPANG")) ; to record what it was, might not be 0 (setq old_orthomode (getvar "ORTHOMODE")) (setq temperr *error*) ;store *error* ; can wait till here to set error function, after recording old variables (setq *error* 11error) (setvar "SNAPANG" ang) (setvar "ORTHOMODE" 1) (setq dist (distance p0 (getpoint p0 "Pick a second point >"))) (setvar "SNAPANG" Old_Snapang) ; moved this here, seto to old value (no assumption what it was) (setvar "ORTHOMODE" old_orthomode) (entmakex (list (cons 0 "LINE") (cons 10 p0) (cons 11 (polar p0 ang dist)))) (setq *error* temperr) ; reset error (princ) ) 1 Quote
Steven P Posted January 1 Posted January 1 Yes, use 'abs' where you enter the angle. Will let you have a go to work it out https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-3AF854D7-9B75-4A4B-ABA4-E47DB90FB2F6 Quote
1958 Posted January 1 Posted January 1 4 minutes ago, Steven P said: Yes, use 'abs' where you enter the angle. Will let you have a go to work it out (defun c:11 (/ p0 ang dist) (defun 11error (errormsg /) (setvar "SNAPANG" old_snapang) ; reset variables (setvar "ORTHOMODE" old_orthomode) (setq *error* temperr) ; reset *error* (prompt "\nFunction Canelled.") ) (vl-load-com) (setq p0 (getpoint "Pick the first point >") ang (angtof (rtos (abs (getreal "Enter angle >"))) 0) ) (setq Old_snapang (getvar "SNAPANG")) ; to record what it was, might not be 0 (setq old_orthomode (getvar "ORTHOMODE")) (setq temperr *error*) ;store *error* ; can wait till here to set error function, after recording old variables (setq *error* 11error) (setvar "SNAPANG" ang) (setvar "ORTHOMODE" 1) (setq dist (distance p0 (getpoint p0 "Pick a second point >"))) (setvar "SNAPANG" Old_Snapang) ; moved this here, seto to old value (no assumption what it was) (setvar "ORTHOMODE" old_orthomode) (entmakex (list (cons 0 "LINE") (cons 10 p0) (cons 11 (polar p0 ang dist)))) (setq *error* temperr) ; reset error (princ) ) 1 Quote
Nikon Posted January 1 Author Posted January 1 (edited) @1958 & @Steven PThank you and happy new year! This last code draws a line at an angle (-60) to the right side, if you set the angle (-30), then the dotted line shows the Angle (-60), and the line turns to the right side (30)... Edited January 1 by Nikon Quote
1958 Posted January 1 Posted January 1 You enter the angle value - 30 degrees to the 0-X axis, and move the cursor to the floor at an angle of 120 degrees. Paradox! 1 Quote
