adeladel Posted December 25, 2023 Share Posted December 25, 2023 can anyone help pls. I want cad lsp make 2 linear dim inside the rectangle or room (only 2 dimension at fixed distance 0.5 from top side & left side from it) and lable the room from any numbring option , table option or Radio buttons. thanks to forum . dim room and labele.dwg Quote Link to comment Share on other sites More sharing options...
Kajanthan Posted December 25, 2023 Share Posted December 25, 2023 Try This, (defun c:dimauto (/ ss ent dxf_ent var_cmdecho var_osmode llpt urpt) (defun *error* ( msg ) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (setvar 'cmdecho var_cmdecho) (setvar 'osmode var_osmode) (princ) ) (setq var_cmdecho (getvar "cmdecho")) (setq var_osmode (getvar "osmode")) (setvar 'cmdecho 0) (setvar 'osmode 0) (or sn (setq sn 1)) (initget 4) (if (setq tmp1 (getint (strcat "\nEnter Starting Number : <" (rtos sn 2 0) ">: "))) (setq sn tmp1) ) (while (setq ss (ssget ":S" (list '(0 . "*POLYLINE") ))) (if ss (repeat (setq n (sslength ss)) (setq ent (ssname ss (setq n (1- n))) dxf_ent (entget ent) ) (vla-getboundingbox (vlax-ename->vla-object ent) 'mn 'mx) (setq llpt (vlax-safearray->list mn)) (setq urpt (vlax-safearray->list mx)) (setq midpt (mapcar '(lambda (x y) (/ (+ x y) 2)) llpt urpt)) (command "_.DIMALIGNED" (list (car llpt) (cadr urpt)) urpt (list (car llpt) (- (cadr urpt) 0.5))) (command "_.DIMALIGNED" (list (car llpt) (cadr urpt)) llpt (list (+ (car llpt) 0.5) (cadr urpt))) (make_text (list (car midpt) (- (cadr midpt) 0.5)) (rtos sn 2 0)) (setq sn (1+ sn)) ) ) ) (setvar 'cmdecho var_cmdecho) (setvar 'osmode var_osmode) (princ) );defun (defun make_text (txt_pt txt_val) (entmake (list '(0 . "TEXT") '(8 . "0") (cons 10 txt_pt) (cons 40 0.2895) (cons 1 txt_val) '(50 . 0.0) '(71 . 0) '(72 . 1) '(73 . 2) (cons 11 txt_pt)))) (princ "\nDIMAUTO" ) (princ) DimAuto.lsp 1 Quote Link to comment Share on other sites More sharing options...
adeladel Posted December 25, 2023 Author Share Posted December 25, 2023 thanks for help, its work for dim the room , but not for label room like living room...the autocad request for Enter Starting Number : <1>: , if it possible i want choose number or label from list or command line . when i pick it then the label room insert automatically at the middle of the room .. and thanks again for help .. Quote Link to comment Share on other sites More sharing options...
