Is there any lisp combine multi three different coloured text in one text
Is there any lisp combine the three nearest text in one mtext
I found lisp by lee mac to collect the nearsest text to near point
;; Text 2 Point  -  Lee Mac 2012
;; Prompts for a selection of Text and Point entities and moves
;; each Text entity to the nearest (2D distance) Point entity in the set.
;; Retains existing Text elevation.
(defun c:txt2pt ( / _textinsertion di1 di2 dxf ent inc ins lst mpt pnt sel txt )
   (defun _textinsertion ( elist )
       (if
           (and
               (zerop (cdr (assoc 72 elist)))
               (zerop (cdr (assoc 73 elist)))
           (cdr (assoc 10 elist))
           (cdr (assoc 11 elist))
   (if (setq sel (ssget "_:L" '((0 . "POINT,TEXT"))))
           (repeat (setq inc (sslength sel))
               (setq ent (entget (ssname sel (setq inc (1- inc)))))
               (if (eq "POINT" (cdr (assoc 0 ent)))
                   (setq lst (cons (cdr (assoc 10 ent)) lst))
                   (setq txt (cons (cons (_textinsertion ent) ent) txt))
           (foreach ent txt
               (setq ins (list (caar ent) (cadar ent)))
               (if (setq pnt (vl-some '(lambda ( pnt ) (equal ins (list (car pnt) (cadr pnt)) 1e-8)) lst))
                   (setq lst (vl-remove pnt lst))
                       (setq di1 (distance ins (list (caar lst) (cadar lst)))
                             mpt (car lst)
                       (foreach pnt (cdr lst)
                           (if (< (setq di2 (distance ins (list (car pnt) (cadr pnt)))) di1)
                               (setq di1 di2
                                     mpt pnt
                       (setq pnt (list (car mpt) (cadr mpt) (caddar ent))
                             dxf (cdr ent)
                             dxf (subst (cons 10 pnt) (assoc 10 dxf) dxf)
                             dxf (subst (cons 11 pnt) (assoc 11 dxf) dxf)
                       (entmod dxf)
                       (setq lst (vl-remove mpt lst))
(vl-load-com) (princ)
There has been a few convert text to mtext lately maybe at Forums/autodesk. Ok for your situation if the text is on 3 layers no dwg supplied, you can get say the yellow text and its angle, make a little 4 point box based on this text, you use this to find the other 2 text and based on their layer name make a new Mtext.
You need to post a sample dwg, no good guessing text size etc.
