seawind Posted December 19, 2023 Posted December 19, 2023 Is there any way to entmake a nested block. Trying to create an annotative block inside a non annotative but when i try to endblk nested block getting error message. Quote
Steven P Posted December 19, 2023 Posted December 19, 2023 What is the process you are following to create both bocks? If you create the non-annotative block and and then try to create the annotative block it might fail. Create the nested block definition first if you can and then insert it into the parent block. 1 Quote
