Obtain photography coordinates
robierzo
Hello. I wanted to know if it is possible to obtain the coordinates of a photograph by using Lisp. The photograph was taken with a drone. I attach an image capture, in which the properties appear, when I right-click on the photograph. Thank you so much.
Yes you can get at the properties of an image ie Lat & Long, in this case I used an external program to get the image properties making a script, inside CIV3D lat long import is supported, so inserted multiple images in one go, the images came from a mobile phone. Trying to remember the name of the program. There was a post some where recently about getting file details.
Hello Bigal. That's exactly what I want to do. Insert the images in their position, according to the latitude and longitude information. Can you give more details on how to do it? Thank you!!!
12 hours ago, rcb007 said:
Thank you so much rcb007. It's just what she needed. Thank you.
