I have a survey with the topographic elevations (not annotative) called out with leaders.
I would like to scale all those leaders by "x" all at the same time and all from the tip of the leaders (individually).
Is there a Lisp routine that I can use to do this?
I am currently selecting each individual one and applying the scale command. This is very time consuming and tedious, any help will be greatly appreciated.
23-1906ATOPOSTRIP.dwg
How much do you know about lisp ? You can select "Leader"
(defun c:wow ( / ss le x pt oldsnap leent co-ord)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(setq sc (getreal "\nEnter scale value "))
(setq ss (ssget '((0 . "*LEADER"))))
(setq le (ssname ss (setq x (1- x))))
(setq leent (entget le))
(setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) leent)))
(setq pt (caddr co-ord))
(command "scale" le "" pt sc)
(setvar 'osmode oldsnap)
(setvar 'osmode 0)
I do not know how to create what you just created but I do know how to save it, load it and use it. Thank you!!
With that said, when I do use it in the original file it work flawlessly.
I then scaled the drawing to be 1:1 and now the leaders move to a different location after using your lisp.
Another thing that happens is that all my osnap settings get cleared.
If its crashing out then it is not running the last line (setvar 'osmode oldsnap) which resets the osnaps back to what they were.
I stay away from annotative so dont get these problems.
Post the dwg again with the annotation scale reset, also I am metric scales much easier.
  • 2 weeks later...
Here is the file again. Thanks for the help so far.
The leader has a base point some 2900 in X direction similar Y that is why its not working I dont think its got anything to do with annotative. Some where inside the leader properties is an answer, also noticed the leader line is made up of 2 objects. The leaders have been created in some other way.
Sorry can not help any more. Some one else may have an idea.
  • 2 months later...
(setvar "osmode" oldsnap)
It works...
If you change the code a little bit:
;; changes the scale of all LEADERS that are included in the selection frame
;; MLEADERS keep the starting point
;; osmode returns the initial value
(defun c:wow1 ( / ss le x pt oldsnap leent co-ord)
(setvar 'osmode 0)
(setvar "osmode" oldsnap) ;; replacing this string (setvar 'osmode oldsnap)
;; changes the scale of all LEADERS in the drawing without selection
(defun c:wow2 ( / ss le x pt oldsnap leent co-ord)
(setvar 'osmode 0)
(setq ss (ssget "_X" '((0 . "*LEADER")))) ;; replacing this string(setq ss (ssget '((0 . "*LEADER"))))
