Dien nguyen Posted December 7, 2023 Posted December 7, 2023 Currently I have written a lisp to get Hatch property information including Layer Name and Area into Mutileader, now it works. How it works is as follows: Load lisp => HJ command => Pick Hatch, Pick point, Pick point => Done Then I want to edit the lisp to be able to work with blocks, but when I insert the block I don't see a place to insert the properties taken from Hatch. Below is the lisp with Mutileader and attached is my final completed block. (vl-load-com) (defun Get-ObjectIDx64 (obj / utl) (setq utl (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object)))) (if (= (type obj) 'ENAME)(setq obj (vlax-ename->vla-object obj))) (if (= (type obj) 'VLA-OBJECT) (if (> (vl-string-search "x64" (getvar "platform")) 0) (vlax-invoke-method utl "GetObjectIdString" obj :vlax-False) (rtos (vla-get-objectid obj) 2 0)))) (defun C:HJ (/ obj objID area hname content units) (while (setq sset (car (entsel))) (setq obj (vlax-ename->vla-object sset)) (setq objID (Get-ObjectIDx64 obj)) (setq hname (strcat "%<\\AcObjProp Object(%<\\_ObjId " objID ">%).Layer \>%" )) (if (getvar "INSUNITS") ; (setq units (getvar "INSUNITS")) (setq units 4) ; ) (setq area (cond ((= units 4) ; (strcat "%<\\AcObjProp Object(%<\\_ObjId " objID ">%).Area \\f \"%lu2%pr1%ct8[1.0E-006]\">%")) ((= units 6) ; (strcat "%<\\AcObjProp Object(%<\\_ObjId " objID ">%).Area \\f \"%lu2%pr1\">%")) ) ) (setq content (strcat hname "\n" area "m²")) (if (and (setq pnt (getpoint "\nPick Leader Base point: ")) ;(setq pnt (trans pnt 1 0)) ) (command "_.mleader" "_none" pnt PAUSE content) ) (princ) ) ) Tag Block.dwg Quote
BIGAL Posted December 7, 2023 Posted December 7, 2023 (edited) You dont need a defun for ID may have been needed for older Cad versions. I just re-arranged a bit. (defun C:HJ (/ obj objID area hname content units) (while (setq obj (vlax-ename->vla-object (car (entsel "\nSelect hatch Enter to exit ")))) (setq objID (rtos (vla-get-objectid obj) 2 0)) (setq hname (strcat "%<\\AcObjProp Object(%<\\_ObjId " objID ">%).Layer \>%" )) ; (if (getvar "INSUNITS") ; is this needed ? (setq units (getvar "INSUNITS")) ; (setq units 4) ; ) (cond ((= units 4)(setq area (strcat "%<\\AcObjProp Object(%<\\_ObjId " objID ">%).Area \\f \"%lu2%pr1%ct8[1.0E-006]\">%"))) ((= units 6)(setq area (strcat "%<\\AcObjProp Object(%<\\_ObjId " objID ">%).Area \\f \"%lu2%pr1\">%"))) (progn (Alert "Incorrect insunit value")(exit)) ) (setq content (strcat hname "\n" area "m²")) (setq pnt (getpoint "\nPick Leader Base point: ")) (command "_.mleader" "_none" pnt PAUSE content) ) (princ) ) Edited December 7, 2023 by BIGAL Quote
Dien nguyen Posted December 8, 2023 Author Posted December 8, 2023 With this lisp it work with multileader, However I find way to insert block with property of selection hatch. Quote
