3dwannab Posted December 6, 2023 Share Posted December 6, 2023 Is there a method to select the objects in the ssget filter below that don't have hatches associated with them? I was to incorporate it into this lisp that hatches each object with the layer and other props of each of the objects in the selection set. (vl-load-com) ;; See thread here: https://www.cadtutor.net/forum/topic/77467-hatch-to-each-of-the-closed-polylines-match-the-colour-layer/ ;; Program to hatch objects in the ssget filter below to match the layer, colour and transparency of each object. ;; Answer by fuccaro and added undo handling and changed the selection method by myself (3dwannab) ;; First written on 2023.05.11 (defun c:HBC nil (c:HH_Boundary_Colour)) (defun c:HH_Boundary_Colour (/ *error* acDoc var_cmdecho var_osmode s sp h f) (defun *error* (errmsg) (and acDoc (vla-EndUndoMark acDoc)) (and errmsg (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " errmsg " >>\n")) ) (setvar 'cmdecho var_cmdecho) (setvar 'osmode var_osmode) ) (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)) (setq var_cmdecho (getvar "cmdecho")) (setq var_osmode (getvar "osmode")) (setvar 'cmdecho 0) (setvar 'osmode 0) ;; RJP » 2023-05-18 (cond ((setq s (ssget '((0 . "CIRCLE,ELLIPSE,*POLYLINE,SPLINE")))) (setq sp (vlax-ename->vla-object (cdr (assoc 330 (reverse (entget (ssname s 0))))))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (cond ((vlax-curve-isclosed e) (setq h (vlax-invoke sp 'addhatch achatchobject "SOLID" :vlax-true)) (vlax-invoke h 'appendouterloop (list (vlax-ename->vla-object e))) (setq f (vl-remove-if-not '(lambda (x) (member (car x) '(8 62 420 430 440))) (entget e))) ;; Match layer and byobject colors (entmod (append (entget (vlax-vla-object->ename h)) f)) (vla-evaluate h) ) ) ) ) ) (*error* nil) (princ) ) ; (c:HBC) (princ (strcat " \n: ------------------------------\n'Hatch_Boundary_Colour.lsp' Loaded | Invoke by typing 'HH_Boundary_Colour' or 'HBC'.\n: ------------------------------\n")) (princ) Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 6, 2023 Share Posted December 6, 2023 Might be wrong but the hatch borders are separate from the hatch itself, the link is made in the hatch definition? You'd probably need to filter for hatches and polyline / circles / ellipse etc., then loop through the hatch definitions and remove the entity definition from the selection sets that the hatch refer to? Not something I've thought about doing - but could be handy to some to exclude hatch boundaries or include them. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 6, 2023 Share Posted December 6, 2023 If a hatch is associated to an object then you can find it attached in the dxf codes of the host object between the reactor opened & closed brackets. Happy digging. 1 Quote Link to comment Share on other sites More sharing options...
3dwannab Posted December 8, 2023 Author Share Posted December 8, 2023 Thanks @Tharwat, is it the 102 one? Quote Link to comment Share on other sites More sharing options...
Steven P Posted December 8, 2023 Share Posted December 8, 2023 I make it the last 330 (assoc 330 (reverse.....)) 1 1 Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 8, 2023 Share Posted December 8, 2023 4 hours ago, 3dwannab said: Thanks @Tharwat, is it the 102 one? As Steven stated earlier , it's the 330 GC and this is if the object associated with hatch object otherwise the 330 will be only one and related to the session where the object positioned / located. 2 Quote Link to comment Share on other sites More sharing options...
