leonucadomi Posted December 4, 2023 Share Posted December 4, 2023 hello all: I am using this magnificent routine makes a list of all viewports and its scales. and sends a warning if there is a wrong scale. I would like the windows with the wrong scales to be painted red to detect them quickly. Can somebody help me? here code ;escalas de todos los viewports (defun c:evp2 ( / ssvp tel ss_ent vlag entlijst hoogte xlijst xhoogte antw i_sch vp_id vlagx vp_test) (command "zoom" 1xp) ; undo (setq ssvp (ssget "X" '((0 . "VIEWPORT"))) tel 0 ss_ent nil) (while (< tel (sslength ssvp)) (setq ss_ent (cons (ssname ssvp tel) ss_ent) tel (1+ tel)) );while (if (cdr ss_ent)(setq ss_ent (cdr ss_ent))) (setq ssvp nil vlag nil vlagx nil) (foreach n ss_ent (setq entlijst (entget n '("*"))) (setq hoogte (cdr (assoc 41 entlijst)) vp_id (cdr (assoc 69 entlijst)) xlijst (cadr (assoc -3 entlijst))) (setq xhoogte (cdr (nth 7 xlijst))) (cond ((> xhoogte hoogte) (setq antw (rem xhoogte hoogte) i_sch (/ xhoogte hoogte))) (T (setq antw (rem hoogte xhoogte) i_sch (/ 1000 (/ hoogte xhoogte)))) );cond (setq vp_test (rem i_sch (fix i_sch))) (if (> vp_test 0.5)(setq vp_test (1- vp_test))) (if (not (equal vp_test 0.0 0.00001))(setq vlag 1 vlagx 1)) (if (= vlagx 1) (princ (strcat "\nViewport " (itoa (1- vp_id)) " is scale 1:" (rtos i_sch 2 8))) (princ (strcat "\nViewport " (itoa (1- vp_id)) " is scale 1:" (rtos i_sch 2 0))) ) (princ "\n ") (setq vlagx nil) );foreach (if vlag (alert "One or more viewports have got a wrong scale !")) (princ) );defun Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 4, 2023 Share Posted December 4, 2023 My $0.05 Did you use chatGP for code ? (defun c:evp2 ( / ssvp tel sc vlag obj) (setq ssvp (ssget "X" '((0 . "VIEWPORT")))) (if (= ssvp nil)(progn (alert "NO viewports selected \n \nWill exit now ")(exit))) (repeat (setq tel (sslength ssvp)) (setq obj (vlax-ename->vla-object (ssname ssvp (setq tel (1- tel))))) (setq sc (vlax-get obj 'customscale)) (cond ((equal sc 1.0 1e-03)(setq vlag 0)) ((equal sc 10.0 1e-03)(setq vlag 0)) ((equal sc 5.0 1e-03)(setq vlag 0)) ((equal sc 50.0 1e-03)(setq vlag 0)) ((setq vlag 1)) ) (if (= vlag 1) (progn (vlax-put obj 'color 1) (alert "One or more viewports have got a wrong scale ! \n \nNow RED color ") (setq vlag nil) ) ) ) (princ) ) (c:evp2 ) 2 1 Quote Link to comment Share on other sites More sharing options...
mhupp Posted December 5, 2023 Share Posted December 5, 2023 (edited) like to convert everything into vla-object from the selection set by using the foreach and "(mapcar 'vlax-ename->vla-object" (defun c:evp2 (/ ssvp sc vlag) (if (setq ssvp (ssget "X" '((0 . "VIEWPORT")))) (foreach obj (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex sssvp))) (setq sc (vlax-get obj 'customscale)) (cond ((equal sc 1.0 1e-03)(setq vlag 0)) ((equal sc 10.0 1e-03)(setq vlag 0)) ((equal sc 5.0 1e-03)(setq vlag 0)) ((equal sc 50.0 1e-03)(setq vlag 0)) ((setq vlag 1)) ) (if (= vlag 1) (progn (vlax-put obj 'color 1) (prompt "\nViewport has wrong scale!") ;will process all viewports and not stop waiting for user to click ok (setq vlag nil) ) ) ) (alert "NO viewports selected \n \nWill exit now") ) (princ) ) If it displays your View ports have errors should probably have a lisp to go to the tab with the error. ;;------------------------------------------------------------------;; ;; Fine View port (defun c:FVP (/ ssvp) (if (setq ssvp (ssget "X" '((0 . "VIEWPORT") (62 . 1)))) (progn (setvar 'ctab (cdr (assoc 410 (entget (ssname ssvp 0))))) ;go to tab with the first viewport found (prompt (starcat "\n" (rtos (sslength ssvp) 2 0) "Viewports need to be Checked")) ) (prompt "\nDidn't fine any Viewports with error's") ) (princ) ) updated code Edited December 6, 2023 by mhupp 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 5, 2023 Share Posted December 5, 2023 "If it displays your View ports have errors should probably have a lisp to go to the tab with the error." Good idea, I set up 3 layouts with multi viewports for testing. Quote Link to comment Share on other sites More sharing options...
