Change boundary color without using (entlast)
(vl-cmdf "_.-boundary" "_a" "_i" "_n" "" "" "_non" (getpoint) "")
How to write ( if boundary created ) change its colour to yellow without using (entlast)
================================  Also  ================================
How to check if error using (vl-catch-all-error-p (vl-catch-all-apply For This ssget
(ssget "_WP" (pac Poly_Ent) (list (cons 0 "TEXT") (cons 8 "Pr_layer"))))
Check if there is a text (Layer "Pr_layer") inside the closed polyline Poly_Ent because I got error many times while running the code
( bad argument type: lselsetp nil )
(defun pac (e / l v d lst)
        (setq lst nil)
        (setq d (- (setq v (/ (setq l (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e))) 100.))))
        (while (< (setq d (+ d v)) l)
            (setq lst (cons (vlax-curve-getPointAtDist e d) lst))
Edited by Engineer_Yasser
  • Engineer_Yasser changed the title to Change boundary color without using (entlast)
what is wrong with entlast? if you don't want entlast maybe you should use a window selection (getpoint + getcorner) and after selection set & bounday (lwpoly) is created , you create a second selection set using same points from getpoint / getcorner and substract selection set 1 from selection set 2 and whatever is left should be your boundary. Lots of stuf you should be able to find on this site or with googe but why go this path when entlast is the most direct way?  unless you're a female human, like my wife ... she also defies all logic but that's probably just to irritate me haha
Because when using (entlast) and the boundary not created .. the Autocad will deal with the previous entity not the boundary .. so i need to check if boundary created or not first
same like
(if (ssget)
if you made selection the ( if ) will continue
it's not very pretty (unlike me haha) but maybe this could work for you
(defun c:t1 ( / pt cmd fn oqa ocm fp i s)
  (setq fn (getvar 'logfilename))
  (if (findfile fn) (vl-file-delete fn))
  (setq s "" pt (getpoint "\nSelect internal point for boundary : "))
  (setq cmd (list "logfileon" "_.-boundary" "_a" "_i" "_n" "" "" "_non" pt "" "_redraw" "logfileoff"))
  (setq  oqa (getvar 'qaflags) ocm (getvar 'cmdecho)) (setvar 'qaflags 2)(setvar 'cmdecho 1)
  (vl-catch-all-apply 'vl-cmdf cmd)
  (gc)(gc)
  (if (setq fp (open fn "r"))
    (while (setq i (read-line fp))
      (setq s (strcat s i))
  (if fp (close fp))
  (if (and s (wcmatch (strcase s t) "*boundary created*"))
      (alert "boundary created")
      ;;; chprop + entlast bladiebla
    (alert "computer says no")
  (setvar 'qaflags oqa)(setvar 'cmdecho ocm)
Edited by rlx
  (gc)(gc)
  (if fp (close fp))
Nice Work ✅ .. Thanks for help 🌹
@rlx
How to check if error using (vl-catch-all-error-p (vl-catch-all-apply For This 👇
totaly untested...
(cond
  ((not (tblsearch "layer" "Pr_layer"))
   (princ "\nLayer 'Pr_layer' not present"))
  ((vl-catch-all-error-p (setq result (vl-catch-all-apply 'ssget (list "_WP" (pac Poly_Ent) (list (cons 0 "TEXT") (cons 8 "Pr_layer"))))))
   (alert (strcat "Computer says no :\n" (vl-catch-all-error-message result))))
  (t (princ "\nNo errors detected"))
27 minutes ago, rlx said:
totaly untested...
(cond
Not success ... all I want to (ssget  (list (cons 0 "TEXT") (cons 8 "Pr_layer"))) inside selected closed polyline and if (> sslength 1) delete the selected closed polyline .. in case of error skip and continue
