HieuVn96 Posted November 18, 2023 Posted November 18, 2023 hi everyone, I have trouble when I use pline to link between blocks. It take to long time to do . Could you help me a lisp to faster.. Thank you Quote
Steven P Posted November 18, 2023 Posted November 18, 2023 How is the drawing made up, for example, are the rectangles lines or polylines? Might make a difference that in a LISP you could select the rectangles one at a time and draw a polyline to the centre point. If the rectangles are 4 lines then you can either go with selecting opposing points, draw the polyline to the mid-point, or select the whole rectangle but then the LISP would need to distinguish between the rectangle lines and the wire route. I am pretty sure there will also be an answer "Use AutoCAD Electrical" and also an answer asking what you found with an internet search - this has been asked before you see. Quote
Tharwat Posted November 18, 2023 Posted November 18, 2023 You can try my WIRE program. https://autolispprograms.wordpress.com/wiring-program/ NOTE: the trial version is a bit old now but the latest one is much advanced with quite more features. Quote
