CAD Panacea Posted November 18, 2023 Posted November 18, 2023 An incomplete list. Will be updated. Civil 3D 2023 Base = 13.5.131.0 Civil 3D 2023.1 = 13.5.211.0 Civil 3D 2023.2.1 = 13.5.1184.0 Civil 3D 2023.2.2 = 13.5.1212.0 Civil 3D 2023.2.3 = 13.5.1222.0 Civil 3D 2023.3.1 = 13.5.1478.0 Civil 3D 2022 Base = 13.4.213.0 Civil 3D 2022.2 = 13.4.2119.0 Civil 3D 2022.2.1 = 13.4.2128.0 Civil 3D 2021.2 = 13.3.2105.0 Civil 3D 2021.3 = 13.3.2535.0 Civil 3D 2021.3.5 = 13.3.2591.0 Civil 3D 2020.2 = 13.2.1758.0 Civil 3D 2020.6.1 = 13.2.3902.0 Civil 3D 2019 Base = 13.0.613.0 Civil 3D 2019.1 = 13.0.863.0 Civil 3D 2019.2 = 13.0.1175.0 Civil 3D 2019.3 = 13.0.1361.0 Civil 3D 2019.3.1 = 13.0.1410.0 AutoCAD 2020 Base = 23.1.47.0 AutoCAD 2020.1.2 = 23.1.104.0 AutoCAD 2019.1.2 = 23.0.162.0 View the full article Quote
BIGAL Posted November 19, 2023 Posted November 19, 2023 You can pull the current version details from the registry. Yes previously I used (vlax-product-key). Apologise I forget who wrote this. ; vercheck.lsp version check for *aecc objects ; uses registerycheck (defun ah:vercheck ( / vrsn appstr) (vl-load-com) (setq acApp (vlax-get-acad-object)) (setq C3D (strcat "HKEY_LOCAL_MACHINE\\" (if vlax-user-product-key (vlax-user-product-key) (vlax-product-key) ) ) C3D (vl-registry-read C3D "Release") C3D (substr C3D 1 (vl-string-search "." C3D (+ (vl-string-search "." C3D) 1)) ) ) (setq *AeccDoc*(vla-getinterfaceobject (vlax-get-acad-object) (strcat "AeccXUiLand.AeccApplication." C3D) ) ) (setq *aeccDoc* (vlax-get-property *aeccdoc* "ActiveDocument")) (princ) ) If your going to do some stuff with C3D need this to open the application. I have some, the one I like best is Change contour display via a toolbar, something missing in CIV3D using toolspace is a pain. Quote
