lISP ANGLE MEASUREMENT IN AUTOCAD 3D
CongVenh
My last try:
(defun c:pp()
  (setq p1 (cdr (assoc 10 (setq el (entget (car (entsel "Select line   \n "))))))
	p2 (cdr (assoc 11 el))
	p3 (list (car p1) (cadr p1) (caddr p2))
	ang1 (atan (distance p1 p3) (distance p2 p3))
	ang2 (angle p3 p2)
  (strcat  (convert ang1) "   |   " (convert ang2))
(defun convert(a)
  (setq a (/ (* a 180.0) PI)
	d (fix a)
	m (fix (+ 0.5 (* 60.0 (- a d)))))
  (strcat (itoa d) "deg " (itoa m) "min")
14 hours ago, fuccaro said:
My last try:
(defun c:pp()
	ang2 (angle p3 p2)
(defun convert(a)
	d (fix a)
Thank you Fuccaro. The results were exactly what I wanted. Can you help me output that result to the screen instead of reading it from the command line?
What do you mean by "output to the screen"? I could create two TEXT entities, but you will have to place them in the right position. You don't need any more to export the angles to Excel?
(defun c:angles( / p1 p2 p3 ang1 ang2 sel a1 a2 textH)
  (setq p1 (cdr (assoc 10 (setq el (entget (car (setq sel (entsel "Select line   \n ")))))))
	ang2 (angle p3 p2)
  (strcat  (setq a1 (convert ang1)) "   |   " (setq a2 (convert ang2)))
  (setq textH 2)
  (entmake (mapcar 'cons '( 0 1 10 40 62) (list "text" a1 (cadr sel) textH 1)))
  (entmake (mapcar 'cons '( 0 1 10 40 62) (list "text" a2 (mapcar '+ (cadr sel) (list textH textH 0)) textH 4)))
  (export a1 a2)
(defun convert(a / d m)
	d (fix a)
(defun export(a b / f file)
  (setq file (getfiled "Specify out file" (substr (setq name (getvar "dwgname")) 1 (- (strlen name) 4))   "csv" 1))
  (setq f (open file "w"))
  (write-line a f)
  (write-line b f)
  (close f)
	ang2 (angle p3 p2)
  (setq textH 2)
  (export a1 a2)
	d (fix a)
  (write-line a f)
  (write-line b f)
  (close f)
Thank you very much Fuccaro. Thanks to you, my work is easier
