fuccaro Posted November 21, 2023 Share Posted November 21, 2023 My last try: (defun c:pp() (setq p1 (cdr (assoc 10 (setq el (entget (car (entsel "Select line \n ")))))) p2 (cdr (assoc 11 el)) p3 (list (car p1) (cadr p1) (caddr p2)) ang1 (atan (distance p1 p3) (distance p2 p3)) ang2 (angle p3 p2) ) (strcat (convert ang1) " | " (convert ang2)) ) (defun convert(a) (setq a (/ (* a 180.0) PI) d (fix a) m (fix (+ 0.5 (* 60.0 (- a d))))) (strcat (itoa d) "deg " (itoa m) "min") ) Quote Link to comment Share on other sites More sharing options...
CongVenh Posted November 22, 2023 Author Share Posted November 22, 2023 14 hours ago, fuccaro said: My last try: (defun c:pp() (setq p1 (cdr (assoc 10 (setq el (entget (car (entsel "Select line \n ")))))) p2 (cdr (assoc 11 el)) p3 (list (car p1) (cadr p1) (caddr p2)) ang1 (atan (distance p1 p3) (distance p2 p3)) ang2 (angle p3 p2) ) (strcat (convert ang1) " | " (convert ang2)) ) (defun convert(a) (setq a (/ (* a 180.0) PI) d (fix a) m (fix (+ 0.5 (* 60.0 (- a d))))) (strcat (itoa d) "deg " (itoa m) "min") ) Thank you Fuccaro. The results were exactly what I wanted. Can you help me output that result to the screen instead of reading it from the command line? Quote Link to comment Share on other sites More sharing options...
fuccaro Posted November 22, 2023 Share Posted November 22, 2023 What do you mean by "output to the screen"? I could create two TEXT entities, but you will have to place them in the right position. You don't need any more to export the angles to Excel? Quote Link to comment Share on other sites More sharing options...
fuccaro Posted November 22, 2023 Share Posted November 22, 2023 (defun c:angles( / p1 p2 p3 ang1 ang2 sel a1 a2 textH) (setq p1 (cdr (assoc 10 (setq el (entget (car (setq sel (entsel "Select line \n "))))))) p2 (cdr (assoc 11 el)) p3 (list (car p1) (cadr p1) (caddr p2)) ang1 (atan (distance p1 p3) (distance p2 p3)) ang2 (angle p3 p2) ) (strcat (setq a1 (convert ang1)) " | " (setq a2 (convert ang2))) (setq textH 2) (entmake (mapcar 'cons '( 0 1 10 40 62) (list "text" a1 (cadr sel) textH 1))) (entmake (mapcar 'cons '( 0 1 10 40 62) (list "text" a2 (mapcar '+ (cadr sel) (list textH textH 0)) textH 4))) (export a1 a2) ) (defun convert(a / d m) (setq a (/ (* a 180.0) PI) d (fix a) m (fix (+ 0.5 (* 60.0 (- a d))))) (strcat (itoa d) "deg " (itoa m) "min") ) (defun export(a b / f file) (setq file (getfiled "Specify out file" (substr (setq name (getvar "dwgname")) 1 (- (strlen name) 4)) "csv" 1)) (setq f (open file "w")) (write-line a f) (write-line b f) (close f) ) 1 Quote Link to comment Share on other sites More sharing options...
CongVenh Posted November 23, 2023 Author Share Posted November 23, 2023 17 hours ago, fuccaro said: (defun c:angles( / p1 p2 p3 ang1 ang2 sel a1 a2 textH) (setq p1 (cdr (assoc 10 (setq el (entget (car (setq sel (entsel "Select line \n "))))))) p2 (cdr (assoc 11 el)) p3 (list (car p1) (cadr p1) (caddr p2)) ang1 (atan (distance p1 p3) (distance p2 p3)) ang2 (angle p3 p2) ) (strcat (setq a1 (convert ang1)) " | " (setq a2 (convert ang2))) (setq textH 2) (entmake (mapcar 'cons '( 0 1 10 40 62) (list "text" a1 (cadr sel) textH 1))) (entmake (mapcar 'cons '( 0 1 10 40 62) (list "text" a2 (mapcar '+ (cadr sel) (list textH textH 0)) textH 4))) (export a1 a2) ) (defun convert(a / d m) (setq a (/ (* a 180.0) PI) d (fix a) m (fix (+ 0.5 (* 60.0 (- a d))))) (strcat (itoa d) "deg " (itoa m) "min") ) (defun export(a b / f file) (setq file (getfiled "Specify out file" (substr (setq name (getvar "dwgname")) 1 (- (strlen name) 4)) "csv" 1)) (setq f (open file "w")) (write-line a f) (write-line b f) (close f) ) Thank you very much Fuccaro. Thanks to you, my work is easier 1 Quote Link to comment Share on other sites More sharing options...
