awnil Posted November 16, 2023 Posted November 16, 2023 Hello guys! I am trying to get the distance from one point to another, then add it to the given reference as part of a text in the drawing. (The text format is "Ref. 364.80", for example). I have searched over the other topics and this is what I found: and Also, my drawings are all scaled 1:100, so the distance must be divided by 10 before adding the reference cote. Here is the screenshot: Thank you! Quote
BIGAL Posted November 17, 2023 Posted November 17, 2023 This is what you want it is metric. ;Calculates level of a point in cross or long sections ; BY alanh 2014 (setvar "cmdecho" 0) (princ "\n To run just type SRL") ;;-------------------=={ Parse Numbers }==--------------------;;` ;; ;; ;; Parses a list of numerical values from a supplied string. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; s - String to process ;; ;;------------------------------------------------------------;; ;; Returns: List of numerical values found in string. ;; ;;------------------------------------------------------------;; (defun LM:ParseNumbers ( s ) ( (lambda ( l ) (read (strcat "(" (vl-list->string (mapcar (function (lambda ( a b c ) (if (or (< 47 b 58) (and (= 45 b) (< 47 c 58) (not (< 47 a 58))) (and (= 46 b) (< 47 a 58) (< 47 c 58)) ) b 32 ) ) ) (cons nil l) l (append (cdr l) (list nil)) ) ) ")" ) ) ) (vl-string->list s) ) ) (defun c:SRL () (setq olddimzin (getvar "dimzin")) (setvar "dimzin" 0) (if (= dwgscale nil) (setq dwgscale (/ 1000.0 (getreal "\n enter vertical scale "))) ) ;(setq datum (getreal "\n Enter datum level ")) (setq datum (car (LM:ParseNumbers (cdr (assoc 1 (entget (car (entsel "\nPick datum text")))))))) (setq test 1) (setq pt1 (cadr (getpoint "\npick datum"))) (while (= test 1) (setq pt2 (cadr (getpoint "\npick point"))) (setq dist (/(abs (- pt1 pt2)) dwgscale)) (setq en1 (car (entsel "\nSelect text number:" ))) (if (/= en1 nil) (progn (setq tent (entget en1)) (setq a (+ dist datum)) (setq a (rtos a 2 3)) (setq el (subst (cons 1 a) (assoc 1 tent) tent)) (entmod el) );progn (princ "\nplease pick again"); else );if ); while t (setq el nil en nil a nil en1 nil test nil) (setvar "cmdecho" 1) (setvar "dimzin" olddimzin) (princ) ) ;ends main defun 1 Quote
awnil Posted November 17, 2023 Author Posted November 17, 2023 Thank you! And thank you for the scale selection. I have tested and it works very fine. Have a look. It worked perfectly with a 100 scale. Big hugs. legatura -transversale pt lsp.dwg Quote
awnil Posted December 6, 2023 Author Posted December 6, 2023 Suchlike, I would like to find a point from the reference up, with the distance I need. I attach the drawing. legatura -transversale pt lsp.dwg Quote
BIGAL Posted December 6, 2023 Posted December 6, 2023 Look at the code and make a new function, you know the datum XY and RL 133.0 you know the scale so the distance is add to datum the difference * scale etc, if you enter a chainage can work out a X offset point from say 0.0 line. You have the Y value so draw circle etc. Have a think about the select sequence, datum point datum rl text 0.0 line maybe use as datum point Need Hor and Ver scales. Have a go a good learning exercise the Surface rl.lsp has all the code you need. Make a copy of it and start there. Quote
